USB (Printer) connection prevents Booting!??
14
Hi again
....am now aware that normal booting only achievable when my USB printer is disconnected.
Can't begin to understand what is happening here.
Asus P8Z68-VLX / Intel i3 2120 / Win 8 Pro 64
    Windows 8 Pro 64-bit (6.2, Build 9200)
    Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz (2 CPUs), ~3.3GHz
    Asus P8Z68 - VLX
    8192MB RAM
    NVIDIA GeForce GT 430
    Samsung BX2231
    ADATA SSD S510 120GB (O/S)
    Seagate 2TB (ST2000DM001-9YN164)
    WD 1TB (WD10EARS-00MVWB0)
    Seagate 500GB (ST500DM002-1BD142)
    OCZ - ZS550W
    Chrome
    Comodo
MilesAhead
Eclectician
2,130
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
14
    Asus P8Z68 - VLX
    8192MB RAM
    Samsung BX2231
    OCZ - ZS550W
    Chrome
    Comodo
MilesAhead
Eclectician
2,130
Printer make and model?
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
14
    Asus P8Z68 - VLX
    8192MB RAM
    Samsung BX2231
    OCZ - ZS550W
    Chrome
    Comodo
MilesAhead
Eclectician
2,130
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
14
So have you tried any solutions/work-arounds yet? .......
Work-arounds...??....well unplugging the printer seems to sort out the booting problem!
Have no idea why this has suddenly become an issue...have owned printer from new, and has worked fine in XP, Vista, Ubuntu, Win7, and Win8 until problem arose some days ago.
Device manager is not indicating any problems in system.
    Asus P8Z68 - VLX
    8192MB RAM
    Samsung BX2231
    OCZ - ZS550W
    Chrome
    Comodo
Wullail
Active Member
467
#8
Just a guess , but it includes a slot for SD cards that the PC can read as a USB device?
Perhaps your PC is trying to boot from the 'USB' slot?
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
MilesAhead
Eclectician
2,130
#9
Only thing I can suggest is disconnect the printer on both ends of the USB cable. With both PC and printer powered up, connect the USB first to the PC, then to the printer. See if it says antthing about a driver loading, new hw found etc..
Check if updates were installed around the same time this issue popped up.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
Wullail
Active Member
467
#10
Any update on this one? , we seem to have a lot of people asking for help , getting answers and then just disappearing right now..
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
MilesAhead
Eclectician
2,130
#11
I haven't heard anything.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
14
#12
OK...you just beat me to it....well you are Milesahead!!
No, Wullail, I haven't found a solution, and then quietly disappeared!!
In 'Devices and printers'...I've noticed a yellow exclamation...and further poking reveals that 'USB Mass storage device has a problem'
A 'FIX' is offerred, but this fails to work.
BTW....I went to the Epson driver page....but am totally confused as to whether or not the latest driver has 'installed':eek:
    Asus P8Z68 - VLX
    8192MB RAM
    Samsung BX2231
    OCZ - ZS550W
    Chrome
    Comodo
MilesAhead
Eclectician
2,130
#13
Right click on the item with the yellow bang and uninstall it. Reboot. That's an old Jedi Support Trick. Sometimes plug and play install gets it right and all is well. Not always. But often enough to try.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
14
#14
Right click on the item with the yellow bang and uninstall it. Reboot. .........
Tried this...and machine now doesn't recognise printer!
Could a recent WIN8 update have caused this....and can I do anything about it??
    Asus P8Z68 - VLX
    8192MB RAM
    Samsung BX2231
    OCZ - ZS550W
    Chrome
    Comodo
MilesAhead
Eclectician
2,130
#15
Does it install the driver if you disconnect, then connect first to the PC and then to the printer? Some USB devices are finicky about how they are plugged in. I assume you tried more than one USB port? Also if you can, try the printer on another machine. Maybe it's a hardware issue. I've had USB printers give me trouble over a network. But not hooked to the local machine.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
