USB Power Management changes state
rdwray
301
My laptop's LAN card is bad so I got a dongle, the problem is that when I plug the dongle in the USB port Power Management activates (checks) "Allow the computer to turn off this device to save power". This means that the dongle gets turned off causing a fault if not active for a period of time if I forget to change the setting. Is there a way to completely disable the setting?
    Windows 8 Pro
    Dell Inspiron 1750
    Duo Core 2.5 G HZ
