USB keyboard not working (usb not detecting)
mesaif
1
So i've been tearing my hair out with this problem for the past few weeks, and i've come here for help. Im using an Azio Levetron Mech5 keyboard that i got about a month or so ago, and since an update, it hasn't been detected by my computer unless i take out my laptop battery and start up (and even then, it works only for 5 minutes before blanking out). Open to suggestions, Thank you so much!
Berton
Forever West
591
Is there a reason for an External keyboard [USB?] on your Notebook/Laptop such as the built-in keyboard doesn't work? Most times simply plugging in a USB keyboard works in addition to the built-in keyboard. Same for a mouse and touchpad but the touchpad can be disabled.
    WinVista, Win7, Win8.1, Win10, Mac OS X 10.10, Linux Mint 17.1
    2 Customs and 3 OEM/Brands
    AMD and Intel
Evil Nemesis
IT Master
Lahore,PK
44
1. Remove Update / Reinstall drivers.
2. Try another keyboard to see if that works?
    Windows 8.1 Pro x64
    Custom Build
    Intel Core i5 4430 @ 3.0 GHZ
    Asus H87-PLUS
    8 GB GDDR3
    Asus R9 270 OC 2 GB
    Builtin AMD Hight Defination Audio Controller
    ASUS MS228H 21.5" Wide LED Monitor
    1 TB SATA Seagate
    Seasonic 500w PSU
    Orange
    None
    A4Tech Usb
    A4Tech Usb
    3G via Smartphone (Mobilink)
    Mozilla Firefox, Chrome
    Kaspersky Internet Security 2015
I've had this happen before, and it turned out to be a USB 2.0/3.0 issue. Here are some things to try:
  • Check batteries. Replace even if you think they are good.
  • Make sure your laptop has the correct USB drivers in, and, as suggested by EVIL NEMESIS, update/reinstall USB drivers.
    • NOTE: In the CHIPSET section of the drivers page for your laptop, there may be a SEPARATE USB 2.0/3.0 driver, in addition to the standard chipset drivers.
  • Go into your BIOS and make sure USB mode is set to LEGACY, if available.
  • Is the keyboard USB 3.0? If so, are your drivers current on your laptop?
  • Does it have a connect button on your keyboard?
    • If so, turn off keyboard (if a switch exists), then turn it back on.
    • Press and hold the connect button for 3 - 5 seconds.
    • Let go, and try.
    • Repeat a couple times.
  • Remove ALL USB devices, restart computer, connect ONLY the keyboard.
-WW
    Dual-Boot Windows 8 (upgrading to 8.1 soon) & Kali Linux (formerly Backtrack)
    Toshiba Qosmio G55-Q804
    Intel Core 2 Duo
    PQG55U-03103DB
    4 GB
    NVIDIA GeForce 9200M GS
    NVIDIA
    18.4" Laptop & External LG FLATIRON W2452T 24"
    1680 x 945 (Internal) & 1920 x 1200 (External LG Monitor)
    500 GB Internal (manually upgraded from 320 GB) & 500 GB External SimpleTech Signature Drive "Designed by Pininfarina" (orignally 250 GB, manually upgraded to 500 GB)
    Built-in - power adapter says 120 Watt output
    HUGE
    Multiple internal fans, processor & graphics card
    Built in & External Logtech K750 Solar / Wireless
    STAPLES B250 Wireless Optical
    Whatever Aircrack-ng provides, LOL!
    80% Chrome & 19% Firefox & 1% Internet Explorer (still on v10, haven't used it enough to update yet)
    Don't use them usually, slow me down; just Windows Built-In.
    Icons, files, assets, software, et cetera, are always well organized - unlike my life, LOL!
