USB CABLE, Monitor Input, PC input?
What can be done with USB Cable regarding PC? Is it worth it?
I use a Dual monitor cabe, one end plugs into The Display shared Vga Connection. The other 2 allow me to have up to a total of 3 Displays. Is there products that allow more than the standard 2 outputs? Example 4?
Thank you
CountMike
Belgrade , Serbia
4,664
Thank you
USB, even USB3 was never meant for transferring large amount of data needed for HD video, too much conversion has to be made. Laptops are limited by number and type of outputs but desktops can accommodate multiple video cards and even basic cards with Display port that use power of existing GPUs to provide video signal to more monitors or TVs.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
