USB 3.0 Pendrive not working in front usb 2.0 port
22
Hey guys i bought hpx705w usb 3.0 drive.Its not working in front usb ports of my desktop but works fine when plugged in back usb ports.And also works fine on my laptop usb ports. What should i do ?
Running windows 8
Berton
Forever West
591
Do any other USB devices work when plugged into the front ports?
    WinVista, Win7, Win8.1, Win10, Mac OS X 10.10, Linux Mint 17.1
    2 Customs and 3 OEM/Brands
    AMD and Intel
Berton
Forever West
591
I've seen speculation that some front ports simply don't get the same amount of power from the motherboard as the rear ports do, seems to be valid. I have a couple of computers that don't have front ports so I use USB Hubs that fit in place of a floppy drive and take their power from the power supply, similar to the External USB Self-Powered Hubs.
    AMD and Intel
22
I dont think its a power issue as other devices seems to be working fine on same ports but its just this usb 3.0 pendrive that dont work.
Do u think it might be a driver issue ?
vrosa
Tech Addict
It's strange. In my case The problem is when I connect older USB 2.0 Phones/Devices to my USB 3.0 ports. It recognizes the mobiles but I cant see storage space (cards).
Have you tried to assign a drive letter to the device using Disk Management?
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
arachnaut
Sunnyvale, CA USA
282
I have had some difficulty with certain types of USB 3 drives. For example, I have 2 Patriot TAB USB 3 drives that I keep connected to the front panel USB3 ports. Just recently I upgraded them to the same type, but larger size. One works fine, but the other only works at USB 2 speeds in the front. On the back panel it will run at USB3 speeds. Since one works fine and the other doesn't, I suspect the physical construction of the USB 3 pins on the drive that are recessed is somehow involved.
    Windows 8.1 Pro with Media Center (64-bit)
    Custom-build
    Intel Core i7-2600K @ 4.3 GHz
    ASUS P8P67 PRO Rev 3.0
    16 GB G.SKILL Ripjaws X DDR3 SDRAM DDR3 1600 (4 banks 4GB DIMM DDR3 8-8-8-24 5-32-12-7 1T 1.5V)
    NVIDIA GeForce GT 440
    Firewire Focusrite Saffire Pro 14
    LG W2353V
    2 of Seagate Barracuda XT ST32000641AS (2TB ea.);
    1 of Seagate Barracuda Green ST2000DL003 (2TB);
    1 of Hitachi Deskstar HDS722020ALA330 (2TB);
    2 of Seagate Desktop ST4000DM000-1F2168 (4TB)
    Corsair AX850 Gold
    Cooler Master HAF 932 Advanced
    ThermalTake Silent 1156
    Logitech K520
    Logitech M310
    7Mbps
    Chrome
    Kaspersky
    Event Studio Precision 6 powered audio monitors;
    Boston Acoustics CS Sub 10 Powered Subwoofer;
    NI Kore controller;
    NI Maschine controller;
    M-Audio Axiom 61 keyboard controller; expression pedal; sustain pedal;
    ... and tons of audio software ...
    I also keep two USB 3 thumb drives (A: and B:) attached with boot recovery and security stuff that I can boot into from BIOS in case of emergency
22
#8
So what should i do now ?
22
#9
Its not listed in disk management.
arachnaut
Sunnyvale, CA USA
282
#10
I can only suggest you get a USB extension cable and run it from the back, use that in the front.
Or perhaps you can exchange it for another and see if the problem goes away.
    Custom-build
    LG W2353V
    Corsair AX850 Gold
    Logitech K520
    Logitech M310
    7Mbps
    Chrome
    Kaspersky
    NI Kore controller;
