Solved Unkown device in device manger and can't be uninstalled
demonguy
54
Recently i noticed that i have an unkown device in my device manager,its hardware id is "PCI\VEN_1414&DEV_0004&SUBSYS_00041414&REV_00", which seems to be a usb host simulator.
But what on earth is it? I can't delete it, after deleting, it will appear again.
    windows 8 pro 64bit
MilesAhead
Eclectician
2,130
If you right click on it then click Properties it should show the name of the driver. I'm not familiar with it. But deleting will just cause Windows to reinstall the device. I would find out what the driver is for before uninstalling.
Also "if it ain't broke don't fix it" is usually a good rule of thumb to follow. ;)
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
demonguy
54
no, i don't have any name about this. And i just don't know what it is, also i don't know which driver i should install
Here is the screenshot
Also, i didn't plug any new device, so i'm really confused
    windows 8 pro 64bit
50
What you're seeing: Windows is detecting a Plug and Play device but it can't find a driver for it. So, it's getting listed under "Other" devices. Right clicking the device doesn't help because Windows just redetects the device, tries (again) to find a driver for it and can't so it appears (again) under "Other" device.
So now let's figure out what the heck it is/might be. I also found the ID seems to indicate a USB Host simulator (which is odd). Have you added any new devices?? In Device Manager, (along the top) click View->Devices by Connection and show me a screen shot. Since it's an odd device, i first want to see how it connects to your h/w (and if it's a real or virtual device)
    windows 8.1
50
It's not connected the physical bus. That confirms suspicion that it may be a virtual device. I never heard of DsfRoot for DSF either. Will have to do some googling. Will post back tomorrow. Time for bed here. ZZZZZZZZZZZZZZZZZZzzzzzzzzzzzzzzzzzzz :)
    windows 8.1
jds63
N.Y.
2,214
This has something to do with a USB Host controller. Possible any USB Hubs on system. This is odd, reference shows it as old use, back to Windows XP. Yes believe it is like a virtual device possibly . Not much Google info to go by.
Device Simulation Framework Reference (Windows Driver Kit)
Possible whatever not compatible if Windows not able to find anything for it.
    Windows 10 Pro 64bit
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    AZZA Cosmas Black Gaming Case
    84mbps /94mbps
    Norton Security 2015
demonguy
54
#8
You're so kind, you don't need to google for me, i will google by myself. anyway, thanks
    windows 8 pro 64bit
jds63
N.Y.
2,214
#9
Or something that is part of system, but not hooked up right now,another possible reason it shows this way.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
demonguy
54
#10
But the weird part is that I can't delete it. After deleting,it will show up again if I refresh device manager. If it's a virtual device. Why can't I delete it ?
    windows 8 pro 64bit
demonguy
54
#11
Now i found an entry called "Device Simulation Framework 1.0" in uninstall program windows in control panel. And i uninstalled it .Now the unknown device disappears. I don't know if it's a dependency of other programs. I hope no~ _:)з」∠)_
    windows 8 pro 64bit
MilesAhead
Eclectician
2,130
#12
Did you make a Restore Point first? If you did or have a recent one you can run it if something stops working.
Most likely you won't need it.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
jds63
N.Y.
2,214
#13
Yes, good have restore points. I never stated to delete it or uninstall it, as we do not know if you are or were using it and just wasn't hooked up or in use at time. Good reason you get this in Device manager. I am not familiar with this device simulation framework to advice you on it more, not much info on it, as it seemed like an older thing used before Windows 8.
Like MilesAhead said if notice something happens afterwards, had no restore point whatever it was used for will not work.
Next time wait till you know more about something before decide to delete it, cause then you will most likely have to do a reset or refresh, unless you had a restore point.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
demonguy
54
#14
You're right, it's a good habit to have a restore point before i do something like this. Thanks for you advice
    windows 8 pro 64bit
Cliff S
Missing my GIF avatars:(
Bamberg Germany
2,387
#15
    Cliff's Black & Blue Wonder
    Intel Core i9-9900K
    ASUS ROG Maximus X Hero
    ZOTAC GAMING GeForce RTX 2080 Ti AMP! Extreme Edition
    hanteks Enthoo Pro TG
    Trust GTX THURA
    Trust GTX 148
    25+/5+ (+usually faster)
    Edge; Chrome; IE11
    Router: FRITZ!Box 7490
    Sound system: Philips Soundbar HTL2160 w/subwoofer
jds63
N.Y.
2,214
#16
Your Welcome, always good to make one for most cases.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
jds63
N.Y.
2,214
#17
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
