Unidentified Network with LAN please help
hobbes5a
This problem started about 2 days ago when i was starting up my laptop from sleep mode. When i tried to troubleshoot it showed "Ethernet doesnt have a valid ip configuration". So i went through some online threads n tried the following.
I ran ipconfig/release, and it showed "no operation can be performed on local area connection* 13 while it has its media disconnected". The same result for local connection* 12 , WiFi, local area connection and bluetooth.
I ran netsh int ip reset c:\resetlog.txt , n i got
Resetting Interface, OK!
Resetting Neighbor, OK!
Resetting Path, OK!
Resetting, failed.
Access is denied.
Restart the computer to complete this action.
So here is the ipconfig/all , please help. Computer model: Lenovo T440s Win8.1 64bit
Windows IP Configuration
Host Name . . . . . . . . . . . . : Lenovo-PC
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Intel(R) Ethernet Connection I218-LM
Physical Address. . . . . . . . . : 28-D2-44-2C-16-3A
Link-local IPv6 Address . . . . . : fe80::886e:e49b:4a1d:bfd3%23(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.191.211(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 724095556
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1B-9C-78-7A-28-D2-44-2C-16-3A
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Wireless LAN adapter Local Area Connection* 13:
Physical Address. . . . . . . . . : 5C-51-4F-4E-9E-6E
Wireless LAN adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : 5E-51-4F-4E-9E-6D
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Wireless-N 7260
Physical Address. . . . . . . . . : 5C-51-4F-4E-9E-6D
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : IPvE Adapter
Physical Address. . . . . . . . . : 00-FF-EA-F4-88-DA
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 5C-51-4F-4E-9E-71
Tunnel adapter isatap.{25B6A7DC-C92B-4FFB-928C-931AA0FBBF49}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
I don't see IPv4 settings in your post (which is the usual way to access the internet).
Go to Control Panel (or click on Network Icon in taskbar)>Network & Sharing and click on "Change Adapter Settings", that will bring up your Network interface adapter . Then double click it and open its properties.
Is there a "check mark" next to Internet Protocol Version 4?
