Unidentified Network Shows up,not connected/using Ethernet
Sahib201
So this has been showing up for the past week or so under my network connections. I am not using Ethernet as I have no cable plugged into my PC; I have been using WiFi instead. This problem isn't at one place, I have been using WiFi on different routers in few different locations but this "connection" remains there.
Any ideas on what this could be and why it is occurring? Also, it takes at least 2-3 minutes for my computer to connect to WiFi when it is booted after shut down/ sleep on any router. Can this be related to the problem above?
Thanks in advance for your help. :)
    Microsoft Windows 8.1 Version 6.3.9600 Build 9600
    ASUSTek COMPUTER INC./ K55A
    8.00 GB
    Avast
broe23
Retired from the grind
Central IL
3,468
Looks like it still thinks you are connected to the Ethernet connection. You would have to pull up Network adapters in Network Control Center, to see why you are getting the limited connection. You are not using a VPN per chance?
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
Sahib201
I am not using any VPN service. I went to Network Control and found this:
A bunch of connections under that unidentified network.
    8.00 GB
    Avast
Sahib201
I just manually disabled each of those connections under the unidentified network and it is gone for now.
    8.00 GB
    Avast
broe23
Central IL
3,468
Virtual Box is what is causing it.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
