Uncatchable BSOD with KMODE_EXCEPTION_NOT_HANDLED
Nakushimo
1
Hi.
I've bought new PC:
Motherboard: MSI Z97 GAMING 5 LGA 1150
CPU: INTEL Core i7 4790 with Cooler Master "Hyper 212 Evo RR-212E-20PK-R2"
GPU: MSI Geforce GTX 970, GTX 970 GAMING 4G, 4Гб
RAM: CRUCIAL CT102464BA160B DDR3 - 2x8Гб 1600
SSD: 128ГБ 2.5" Plextor "M6S" (SATA III)
HDD: Seagate "ST2000DM001" (SATA III)
ATX FRACTAL DESIGN Core 3500, (FD-CA-CORE-3500-BL) with AEROCOOL Strike-X 600
DVD-RW SAMSUNG SH-224DB/BEBE
I've got BSOD without showing it (even when this option enabled) in random time. Try to plug-off SDD, HDD, video, Ram in different variations. Even try to install windows on HDD without SSD.
I've got the latest versions of BIOS, SSD-firmware and drivers for motherboard and GPU. PC without any OC settings
That's .dmp file View attachment 120914-7500-01.zip and its analyze by windbg
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       [URL]http://msdl.microsoft.com/download/symbols[/URL]
Symbol search path is: [URL]http://msdl.microsoft.com/download/symbols[/URL]
Executable search path is:
Windows 8 Kernel Version 9600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17031.amd64fre.winblue_gdr.140221-1952
Machine Name:
Kernel base = 0xfffff800`b660f000 PsLoadedModuleList = 0xfffff800`b68d92d0
Debug session time: Mon Dec  8 12:44:09.862 2014 (UTC - 8:00)
System Uptime: 0 days 0:47:15.527
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
BugCheck 1E, {ffffffffc0000005, fffff800b67649e2, 0, ff6be010}
Probably caused by : ntkrnlmp.exe ( nt!KiInterruptDispatchLBControl+2f2 )
Followup: MachineOwner
6: kd> !analyze -v
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck.  Usually the exception address pinpoints
the driver/function that caused the problem.  Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff800b67649e2, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: 00000000ff6be010, Parameter 1 of the exception
Debugging Details:
DUMP_FILE_ATTRIBUTES: 0x8
  Kernel Generated Triage Dump
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800b6963138
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
 00000000ff6be010
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
fffff800`b67649e2 48cf            iretq
EXCEPTION_PARAMETER2:  00000000ff6be010
BUGCHECK_STR:  0x1E_c0000005_R
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  System
CURRENT_IRQL:  0
ANALYSIS_VERSION: 6.3.9600.16384 (debuggers(dbg).130821-1623) x86fre
DPC_STACK_BASE:  FFFFD001DAF31FB0
TRAP_FRAME:  ffffd001daf2aaa0 -- (.trap 0xffffd001daf2aaa0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=000000069a1d5233 rbx=0000000000000000 rcx=0000000000000002
rdx=000000000001a686 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800b67649e2 rsp=ffffd001daf2ac38 rbp=0000000000000000
 r8=000000000001a686  r9=fffff800b68f7f80 r10=0000000000000000
r11=ffffd001daf2a900 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up di ng nz na pe nc
nt!KiInterruptDispatchLBControl+0x2f2:
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800b67add47 to fffff800b6762fa0
STACK_TEXT:
ffffd001`daf2a1c8 fffff800`b67add47 : 00000000`0000001e ffffffff`c0000005 fffff800`b67649e2 00000000`00000000 : nt!KeBugCheckEx
ffffd001`daf2a1d0 fffff800`b676ebc2 : 00000000`00000001  00000000`00000002 00000000`000015b6 00000000`00000000 : nt! ??  ::FNODOBFM::`string'+0x3a897
ffffd001`daf2a8c0 fffff800`b676d314 : 00000000`00000000  ffffd001`daf00180 ffffbd3f`ac4cdf00 ffffd001`daf2aaa0 :  nt!KiExceptionDispatch+0xc2
ffffd001`daf2aaa0 fffff800`b67649e2 : fffff800`b6766ac2  00000000`00000010 00000000`00000286 ffffd001`daf2ac60 :  nt!KiPageFault+0x214
ffffd001`daf2ac38 00000000`00000000 : 00000000`00000000  00000000`00000000 00000000`00000000 00000000`00000000 :  nt!KiInterruptDispatchLBControl+0x2f2
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  4
SYMBOL_NAME:  nt!KiInterruptDispatchLBControl+2f2
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP:  53085af2
IMAGE_VERSION:  6.3.9600.17031
BUCKET_ID_FUNC_OFFSET:  2f2
FAILURE_BUCKET_ID:  0x1E_c0000005_R_nt!KiInterruptDispatchLBControl
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0x1e_c0000005_r_nt!kiinterruptdispatchlbcontrol
FAILURE_ID_HASH:  {4c0f3d22-2ec4-769a-54c4-2bc89b721961}
