Solved unallocated space on hd problem
bonnerik
didnt really know where to post this, but here goes.
ive been messing around with my hd today, and ive ended up with 3 partitions. first one in the row is a 1gig partition which might aswell be unallocated, cant really do much with it. then i have the system partition, which you can do nothing to, ive tried third party software, but gotten nowhere. then third and last, i have the primary partition, which i would like the first partition be merged with (the 1 gig unallocated space).
looks like this:
1 gig unallocated space- system part - primary part.
would like it to look like this:
maybe one of you folk know of a way to accomplish this ? any help appreciated.
topgundcp
Download: Free Partition Manager for Window PC | MiniTool Partition Wizard Free Edition
Use: Rufus - Create bootable USB
Then boot up the PC with USB. Right click on the 2nd partition->Move Partition then drag it to the left.
Do the same for 3rd partition and drag to the left. Click Apply on the top left to commit the change.
You'd end up with the 1st partition: System
2nd: Prinmary and 1GB unallocated at the end.
Boot up into Windows: Win+X->Disk Management then right click on the Primary->Extend Partition.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
bonnerik
ive downloaded rufus and ive made the usb bootable. am i supposed to install partition manager on the usb ? thats what i did. when i booted from the usb all i got to is a command prompt looking thing, must be doing something wrong :S
altae
You cannot change the system partition while Windows is running (kind of logical, otherwise what would happen if you e.g. deleted the partition). Make an image of your system drive (whole drive including boot sector and everthing else on to that drive), then download the Gparted live image from here, burn it on a cd and boot from that disc. Now you can change any partition you'd like.
    Windows 8.1 Update 1
    self built
    AMD FX-8350
    Gigabyte GA-990FXA-UD7 Rev. 3
    16 GB
    Zotac GTX 770 Amp 2 GB
    GDATA Internet Security
Brooklyn567
"turn the key" said Pandora's box.....
I would not mess with the partitions if they are not causing you any issues, especially with Windows 8.
Windows 7 and previous is not a problem since you can repair the boot structure with a Win7 Boot repair CD
Windows 8 repair cd seems to not always work and is tempermental...
Adding partitions at the end is ok, and safe... but changing, adding, or deleting partitions before your system or OS partition can cause your system not to boot.
Please take all precautions before you attempt this such as backing up important data, making a recovery cd, and take a physical picture of your partition layout and order...
Saving 1GB of space is nowhere near worth the hassle that will come...
    HP G60
    3 GB
    Nvidia GeForce 8200M G
    1366 x 768
    Chrome and Chromium
    Avast Free & Malwarebytes
topgundcp
When bootup from USB. You should get a screen as shown below and no installation needed:
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
bonnerik
thats not the screen i got, thats a screen i could get if i would open the program up in windows. what do you mean by "and no installation needed ?
bonnerik
im not really doing it for the extra space, 1 gig means nothing to me. im doing it both to learn and because for some reason its bothering me :p
topgundcp
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
bonnerik
ok im on that screen and trying right now, im not succeeding. no matter how i try to move partitions, i always end up with 1 gig, then system partition, and then the windows 8 partition.
bonnerik
oh my bad. i just realised something, that i could extend partitions to the left now also, which made it work. thank you alot! :D
topgundcp
OK. Glad we could help !!!
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
Brooklyn567
just curious, Bonnerik, is your system still booting ok, or did you have to run a boot repair cd?
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
topgundcp
May be I can explain to you. This should not effect anything since these unallocated partitions are not seen by Windows (No volume assigned, just unallocated) and he should not have to do any boot repair.
Here's an example:
As long as you move the unallocated partition around, the rest of the partitions will be unchanged. If you create a partition from the unallocated partition then all partitions # to the right will be shifted by one ie. 2 becomes 3, 3 becomes 4 then you'll have the problem.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
Brooklyn567
gotcha, thanks.. I thought is was an unused or empty partition..
unallocated space is unseen as you say..
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
