unable to connect to wifi on first attempt
soundwave591
hi all, I'm currently having trouble connecting to wifi, on a regular basis.
I have to connect and disconnect multiple times until the connection actually sticks, then its usually fine, ive tried trouble shooting to no avail. can anyone offer any help? likewise when I click the box to connect automatically the next time I go to use my computer it doesnt connect and the box is no longer clicked
I am fairly inexperienced with computers so I might be missing something simple.
I havent updated to 8.1 yet as my connection usually drops, computer is a laptop lenovo G580, the connections are a home one that has worked for xbox,xbone,phones, other laptops, and desktops. the other main connection this is a problem with is my school connection.
thanks for all the potential help
Chuck38
Just livin life
    Windows 10 Pro 64-bit
    Self-built/ Custom
    AMD FX-6300
    MSI 970A-G43
    Crucial Ballistix Sport 8GB
    Asus GTX 750 ti
    HP w2207h
    1680x1050
    Seagate 1TB 3.5" 7200 Hybrid Internal Hard Drive
    Crucial M500 240GB 2.5-inch Internal SSD
    EVGA 500 Watt 80+ Certified ATX Power Supply
    Fractal Design Define R4
    Corsair Hydro Series H55 Quiet Edition Liquid CPU Cooler
    CM Storm Devastator - Red
    Logitech Wireless Performance Mouse MX
    Really fast.
    AVG
    Logitech G230 Headset
chev65
Closed
The G580 is probably has more problems then just about any other machine I've dealt with. One after the other they come in here and complain, wireless complaints and problems with wireless seemingly unfixable on the G580. It's basically a Lenovo driver problem not a Windows 8 problem.
I'd run the update to Windows 8.1 then visit the Lenovo site for the latest drivers then cross your fingers. You might also try updating the firmware on your router.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
broe23
Retired from the grind
If it is at your school. Most likely they have throttled the connection to keep students from hogging the bandwidth from other students. Also if it is wifi, they most likely do not have enough Wireless Access Points in the various buildings on Campus.
There really is not much you can do as a guest on someone else's network, in having them fix them. You and the other students along with staff, could probably press IT & the President of the University or College you attend, to put more money towards IT infrastructure for the students.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
