Unable to connect to Wifi Networks at Work
Sundar Raman
Hi,
I bought a new Sony Vaio laptop with Windows 8 installed in it. I'm able to connect to Wifi networks at home but not at work. My laptop has a "Qualcomm Atheros AR9485WB EG" WiFi driver installed. I tried to rollback the Wifi drivers and connect but still I'm not able to succeed. Could someone please help me out to solve this issue?
Thanks in advance.
Sundar
znod
Can you see the network? What happens when you try to connect?
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
Sundar Raman
Yes I'm able to see the available networks. But when i try to connect, it takes quite some time saying "Verifying and connecting" and then says "can't connect to the network".
Rmsplace
Maybe the connection in your office has the restriction to connect number of users. Try to talk to your network administrator to let you connect to that network.
    Windows 8 Pro x64 with Media Center
znod
I think that, at this point, you should talk to others including, your Network Administrator (if one exists), about your connection problem. Your problem sounds like its source is the network, not your coumputer/Win8.
    EVGA 570 SC
    Gateway
    Dual Boot:
Rmsplace
Did you install the correct driver for your wireless network adapter? There are updated drivers exclusively for windows 8.
znod
Since you are able to connect at home, I still say the source of the problem is the network, not your computer--unless, there is, say, an incompatibility between Win8 and Cisco routers (as you mention). Have you checked to see if anyone else on your office network runs Win8 and connects successfully?
    EVGA 570 SC
    Gateway
    Dual Boot:
