Trying to get Fallout 3 to work
I have done practically everything I can think of to get it moving, but the game will still hang when doing things. I've done absolutely everything and I mean EVERYTHING suggested by Steam users but nothing stops the hangs, and nothing significant pops up in the event viewer.
Asus G75VX-RH71-CA w/ Core i7-3630QM, 12GB, 750GB, DVD+/-RW, 17.3in FHD, GeForce GTX 670M, Win 8 64-bit at Memory Express specs.
Nice specs!
The cpu is familiar. ;)
The game might try to run with the weaker graphics card Intel HD4000 by default.
Instead of double-clicking on the game shortcut or exe, right click on it and choose: run with graphics processor -> Nvidia (or High performance...).
Also make sure the drivers are up to date, especially the graphic ones.
Good luck.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
Those are great specs, you should have no issues whatsoever running an old game like FO3. I think my CPU is the same as yours, you have the newer model G75VX, whereas I have the slightly older G75VW. They are nearly identical in most ways though. I've had my laptop for around 8 months, and it runs great, so I see no need to go burn cash on the G75VX. I'm not sure if your model has just a dedicated NVIDIA card, or NVIDIA+Intel HD 4000, so Hopachi may be correct in saying that the game might be trying to use the weaker of the 2 cards. My laptop has only a dedicated NVIDIA card, so I know for certain that any game I run will use that card since it's the only thing available. As for the game itself, just keep it on highest settings since your PC can beast it, although you may want to consider running the game in a borderless window, which will make it appear to be fullscreen when it really isnt. Bethesda's games have a bad habit of crashing when Alt-Tabbing, borderless window will fix this and make it more stable. And be sure to verify the game's cache files with Steam. That's pretty much all I can think of.
    Windows 8.1 Pro x64, Windows Server 2012 R2 x64
    Lenovo G700
    Intel Core i7-3632QM, 2.20 GHz
    Lenovo
    6 GB DDR3
    NVIDIA 720M, Intel HD 4000
    1 monitor
    1600x900 (max)
    1 TB HDD (5400 RPM), 1.5 TB HDD (5400 RPM) installed in a 12.7mm disc drive caddy
    Lenovo
    Lenovo
    Laptop/notebook keyboard/touchpad
    It varies, since I'm mobile most of the time
    Chromium (the open-source browser which Google Chrome is derived from)
    Kaspersky, Malwarebytes, Spybot, Privatefirewall
    I will add more information here later
Curious, did you buy the game from Steam or is it from a retail box?
    Windows 8.1 Professional 64-bit
    Custom
    Intel Core i5-3570k
    ASRock Intel Z77 Extreme4
    8GB
    NVIDIA GeForce GTX 670
    Hyper 212
I bought my copy from Steam because it includes all the DLC and is prepatched to the latest version, but what I've said above should also apply to the retail version. They are pretty much identical, for all intents and purposes.
    Lenovo G700
    Lenovo
    6 GB DDR3
    1 monitor
    1600x900 (max)
    Lenovo
    Lenovo
I upgraded the OS from Win 7 to Win 8. I have just played 30 minutes or so and had no issue at all. Mine was bought on Steam too, with all DLC included when it's on sale.
Thinkpad E420
    Window 7
    ThinkPad
    i5
    Intel family
    4 GB
    ATI/Intel
