Triple Installation : Where is my E: Drive
kapilarya
Banned
I have four drives on my laptop...
C: Windows 7
D: Windows 8 CP
E: Ubuntu 11.10
F: Files/Documents
But I observed that my E: drive is invisible when I view it through the explorer of Windows 8. I want to know how can I make this drive visible again so that I can move some of my files to this drive?
Also will the format of Ubuntu make the drive visible again... but I am confused which drive to format?!
Apologies if same thread exists, give me its link if so...
Any help would be appreciated :think:.
    Windows 8 RP, Windows 7
    HP / Compaq 610
    Intel Core 2 Duo
    1300x768
GMan
Banned
Windows can't read it natively because it's a Linux partition. You'll have to look into a third party solution to install in Windows to read/write/recognize the specific file system, likely ext3 or ext4.
Then you can right click the partition in Disk Management and assign it a drive letter if the 3rd party solution didn't do so already.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
kapilarya
Banned
Thanks GMan for reply..
Can you please tell me which third party solution you're talking about? Actually I didn't got it:what:
    HP / Compaq 610
    Intel Core 2 Duo
    1300x768
