Long story short, my Asus has a bug where if I unplug it when the screen is closed the touchscreen's driver is disabled. requiring me to manually reenable it. Everything that you would logically think would stop this bug does not work, not even explicitly telling Windows to not disable USB devices EVER. I would like the problem to go away or resolve itself automatically, but there seems to be no solution to this and Microsoft has Clippy doing technical support on their forums. I can create a script or batch file, but I would like it to trigger automatically, without having it running all the time. Seeing that the problem occurs only when the power is unplugged, I would like to try to have the script run shortly after unplugging.
Is there a way to trigger a script when the power cable is unplugged, ideally in a clean and efficient manner? thanks.
- Windows 8.1
- Computer type
- Laptop
- System Manufacturer/Model
- Asus Tansformer Book Flip TP500LN
- CPU
- Intel i5-4210U
- Memory
- 8GB DDR3 SDRAM
- Graphics Card(s)
- Nvidia Geforce GT 840M
- Monitor(s) Displays
- 15" Touchscreen
- Screen Resolution
- 1366 x 768
- Hard Drives
- 1TB Hybrid
- Mouse
- Microsoft Wireless Mobile Mouse 4000
