Thunderbolt to display port monitor. GTX 765m
aroton
2
Hey,
I am on a laptop with a gtx 765m. I am trying to connect a thunderbolt port to a display port monitor. My understanding is that thunderbolt is backwards compatible with display port. But, for the life of me I can not get it to work.
I am using a minidisplay port -> display port cord.
I have ended up hooking the monitor up with an hdmi cord for now. FYI the monitor is a 2560x1440 monitor if that matters.
Thanks,
Saltgrass
1,121
Do you know for sure the video is ported through the Thunderbolt connector?
Any chance we could get your computer model number?
    Windows 8.1 x64
    Home Grown
    i7 3770K
    ASUS P8Z77 -v Pro, Z87-Expert
    16 G
    EVGA GTX 680 Classified (2)
    Kingston SSD 240 GB
Saltgrass
1,121
Well, the owner's manual says it is supposed to port the video through the Thunderbolt port. It seems to use Fn+F8 to turn on the secondary monitor or pick between them.
The bios has a couple of options that might be involved and those would be Graphics Configurations and Intel Thunderbolt on the Advanced Options page.
Since I do not have such a setup (yet) I have to think the cable you are using is compatible.
I suppose the only other thing would be to make sure the monitor is looking for the Display Port input. Some monitors are set up to scan for inputs (which I don't like) where others might need to be set for one input in particular.
    Windows 8.1 x64
    Home Grown
    i7 3770K
    16 G
    Kingston SSD 240 GB
Saltgrass
1,121
I just set up my new board, which has Thunderbolt. I enabled the Intel Thunderbolt in the bios and loaded a Thunderbolt driver.
I rebooted with a mini-display to Display Port cable and the monitor recognized it immediately.
Since you have not responded, perhaps you have your situation resolved....
    Windows 8.1 x64
    Home Grown
    i7 3770K
    16 G
    Kingston SSD 240 GB
