system32 and Bios problems
khenyat
11
I want to reformat my pc since im changing my OS from 8.1 to 7. problem is i cant access BIOS. Bios can be access by clicking f2/Delete button when the logo starts up or by going to pc settings and troubleshoot. Sadly both did not work on me, when my pc starts up, it black screens, then i will take around 5-7 mins then the welcome screen pops up skipping the F2/delete clicking portion to access bios, i tried spamming the f2 and delete while it was black screen nothing happens. Now when i access the pc setting, it wont run also, it just shows its logo and it auto minimize. I tried reading some post on how to access pc setting, and it says i run the command prompt as admin, but it wont work cmderror.png . Also when i run some programs, like msconfigexe it shows the problem "specified procedure not found" , saying that i was from windows/system32. HELP! i cant enjoy my pc. pls help. ADVANCE THANKYOU! :eek:
Try F-2 or Delete just as soon as the restart starts.
Don't wait for messages or logos.
Press & hold.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Have you considered reinstalling your OS ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
TechnoMage
Active Member
Central Florida
390
There is NO WAY to access your BIOS from within Windows. Period!
You must do a COLD Start and the second that power is applied to your PC, you must start tapping the F2 key, if that's the correct one for your PC. Mine is not the F2, but the Del key. It varies from PC to PC. On some PC's it's the Esc key.
Occasionally, for some reason, I have to do a Master Reset on my BIOS.
I remove all power from my system, (Desktop PC) and then remove the CMOS battery for at least 30 minutes. That allows all the memory cells in the BIOS to drop to Zero. Then I replace the battery, restore power and boot up the PC, tapping the DEL key from the moment I press the ON button. Then I completely remake all my BIOS settings, save and reboot.
Sounds like you're not ever getting into your Bios Setup.
Good luck
:cool:
    Win-8.1
    Gigabyte
    AMD 8 Core
    Gigabyte
    PNY, 4GB
    NVIDIA, GForce 210
    21" HP
    Seagate SATA III, 500GB
    Antec Earthwatts, 650
    Pac-Man Case
    HP Professional
    GearHead Wireless
    5 Meg
    AVG Free
    Using Classic Shell on Win-8.1 pro
khenyat
11
Good luck
:cool:
are there other ways? i cant reformat since bios is needed.
broe23
Retired from the grind
Central IL
3,468
Fn+F2. You do not need to access the bios to reinstall the OS. Unless somehow boot drive choice got turned off, or you are wanting to disable UEFI & Secure boot.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
alphanumeric
slightly off center
Gold Member
#8
You can't format the drive from the BIOS by the way. You can format the drive during the windows install though. Just chose the custom option and you'll get a screen where you can delete partitions, create new ones and format them. As mentioned, you want to press the key before the logo shows on screen.
Try this. Power down, unplug the power pack and remove the battery. Now press and hold the power button for say 10 seconds or more. Now put the battery back in, plug the power pack back in, and power up while pressing the BIOS access key.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
khenyat
11
#9
is the uefi disabled when it is not showing ? uefipeg.png this does not show on mine when i access the shift+restart button. Please help! :(
alphanumeric
slightly off center
Gold Member
#10
The UEFI Firmware Settings option in Advanced options will only be there if Windows was installed in UEFI mode. If Windows was installed in legacy mode or it is not a UEFI BIOS, you won't get that option. If you can get as far as Advanced options try Startup Repair, if you haven't already that is.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
alphanumeric
slightly off center
Gold Member
#11
You may if you have to change the boot order to boot from your install media? I think technically, even the quick boot menu is accessing the BIOS. Is Fn+F2 the quick boot menu or the factory recovery?
    Asus
    Thermaltake TR 620
    Stock heatsink fan
khenyat
11
#12
i already tried startup repair. it only lessens the time of the blackscreeb. for example last it was 5-7 mins it reduces to 3 mins . help please. please reply why does this happen to my desktop. ill be at school now. be back after 12 hrs. thankyou all in advance !
khenyat
11
#13
i know whats the problem, i installed win 8 64 bit drivers instead of win 8.1 64 bit drivers , :( common sense mistake . please read my other thread thank you! http://www.eightforums.com/general-support/60674-help-wrong-installation-drivers.html#post470825
broe23
Central IL
3,468
#14
Windows 8 drivers are Windows 8 drivers. Does not matter if a Service Pack is installed.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
alphanumeric
slightly off center
Gold Member
#15
8.1 is not a service pack, its an upgrade to a new OS. The kernel version number changed.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
