System tray icon customization
jimi21
Joined
Jan 25, 2014
Is there a way to change a software (not system) trayicon for example a download manager or something like that (i'm trying to change Mipony tray icon).I took a look to the forum but i didn't find what i'm look exactly for.
thanks
    Windows 8.1 Pro x64
    HP Pavillon dv6 3041sl
    Intel Core i7-720QM
    Hewlett-Packard 1448
    DDR3 SDRAM Corsair 4096 MBytes x 2 + SSD Samsung 840 Evo 256 Gb + 1tb WD Scorpio Blue (5200 rpm)
    GPU ATI Mobility Radeon™ HD 5650
    Intel 5 Series/34x0 Chipset PCH - High Definition Audio Controller [B2] + ATI/AMD Redwood/Madison/Ca
    AU Optronics B156XW02 V2
    1366 x 768
    20 mps
    Country Flag
    Italy
MilesAhead
Eclectician
Joined
Jun 8, 2010
If you mean the icon that Mipony shows in the tray I think the only way would be via a resource editor. Usually the application uses its standard icon for the tray also. But it doesn't have to. Typically you would replace the first icon in the exe file. But some programs may use a different icon for the tray. You can open the exe with a resource editor and look.
Just be aware that if you make a mistake you could overwrite something in the program. Also I don't know if there's anything that prohibits doing it. Seems unlikely though.
If I don't have the idea what you want to do please post and correct my impression. :)
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
    Country Flag
    USA
jimi21
Joined
Jan 25, 2014
Yes that's exactly what i wanted to do, i tried with resource hacker but no way. Thank you
    Windows 8.1 Pro x64
    Intel Core i7-720QM
    1366 x 768
    20 mps
    Country Flag
    Italy
MilesAhead
Eclectician
Joined
Jun 8, 2010
When you say "no way" did the program give an error or you couldn't find the icon? It's just my idle curiosity. :)
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
    Country Flag
    USA
