Solved System Restore Issue.... Win 8.1
Harrier
Central Coast of California
I had a need to do a system restore the other day. There was a restore point that was just a few days old and was perfect for what I wanted.
The system did it's thing and went to reboot as per usual but when the desktop came up the usual "Sucessful" was not there and it said that it could not complete because there was a file that had caused it to not complet and maybe I should turn off my AV and try again.
I did that and tried again but got the same result and I am not able to do a restore. Is there something that I can try to turn this around.
Harrier.
    64-Bit Windows 8.1 Home
lifetec
Use SFC to check and repair windows systemfiles.
See this tutorial http://www.eightforums.com/tutorials/3047-sfc-scannow-command-run-windows-8-a.html
Note
If SFC could not fix something, then run the command again to see if it may be able to the next time. Sometimes it may take running the sfc /scannow command 3 times restarting the PC after each time to completely fix everything that it's able to.
If not, then run the Dism /Online /Cleanup-Image /RestoreHealth command to repair any component store corruption, restart the PC afterwards, and try the sfc /scannow command again.
    windows 8.1
    self build
    Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
    Asrock P55 Pro
    DDR3 Team--Elite-1333 8 gb
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    OCZ Stealth 600 watt
    Antec 300
    Speedlink Ledos and Nexus
Harrier
I did as the sfc option 2 suggested but it said that I should be an administrator to run this.
I am the only user and I thought I was accepted as admin on this system.......
How do I correct this please.
lifetec
You need to use the commandprompt(admin)
Take the cursor to the bottom left corner and right-click to open the WinX menu. Select Command Prompt (Admin) to open an elevated command prompt.
    windows 8.1
    self build
    Asrock P55 Pro
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    Antec 300
Harrier
OK, I did one scan and it said it did fix some but not all errors and I remember that I might have to do this a few times... but if you need the scan results for each, please let me know.
Harrier
I tried to do another scan.... nothing, it just sat there. I restarted the PC and tried again and after 10 minutes it was still not doing another scan....... Did I miss something?
But for now, here is the #1 scan log....
2016-05-17 09:42:06, Info CBS TI: --- Initializing Trusted Installer ---
2016-05-17 09:42:06, Info CBS TI: Last boot time: 2016-05-15 13:31:51.494
2016-05-17 09:42:06, Info CBS Starting TrustedInstaller initialization.
2016-05-17 09:42:06, Info CBS Ending TrustedInstaller initialization.
2016-05-17 09:42:06, Info CBS Starting the TrustedInstaller main loop.
2016-05-17 09:42:06, Info CBS TrustedInstaller service starts successfully.
2016-05-17 09:42:06, Info CBS No startup processing required, TrustedInstaller service was not set as autostart
2016-05-17 09:42:06, Info CBS Startup processing thread terminated normally
2016-05-17 09:42:06, Info CBS Idle scavenging initiated
2016-05-17 09:42:06, Info CBS Starting TiWorker initialization.
2016-05-17 09:42:06, Info CBS Ending TiWorker initialization.
2016-05-17 09:42:06, Info CBS Starting the TiWorker main loop.
2016-05-17 09:42:06, Info CBS TiWorker starts successfully.
2016-05-17 09:42:07, Info CBS Universal Time is: 2016-05-17 16:42:07.023
2016-05-17 09:42:07, Info CBS Loaded Servicing Stack v6.3.9600.17709 with Core: C:\windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.3.9600.17709_none_fa7932f59afc2e40\cbscore.dll
2016-05-17 09:42:07, Info CSI 00000001@2016/5/17:16:42:07.054 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7ffffcf77f19 @0x7ffffd254984 @0x7ffffd2541bb @0x7ff7b2ffd69a @0x7ff7b2ffe88b @0x7ff8100320f3)
2016-05-17 09:42:07, Info CBS SQM: Initializing online with Windows opt-in: False
2016-05-17 09:42:07, Info CBS SQM: Cleaning up report files older than 10 days.
2016-05-17 09:42:07, Info CBS SQM: Requesting upload of all unsent reports.
2016-05-17 09:42:07, Info CBS SQM: Failed to start upload with file pattern: C:\windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2016-05-17 09:42:07, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2016-05-17 09:42:07, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\windows\servicing\sqm\*_all.sqm, flags: 0x6
2016-05-17 09:42:07, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2016-05-17 09:42:07, Info CBS NonStart: Set pending store consistency check.
2016-05-17 09:42:07, Info CBS Maint: starting/resuming idle maintenance
2016-05-17 09:42:07, Info CBS Session: 30519387_212827318 initialized by client CbsTask.
2016-05-17 09:42:07, Info CBS Maint: processing started. Client: CbsTask, Session: 30519387_212827318
2016-05-17 09:42:07, Info CBS Maint: launch type: ScheduledTask
2016-05-17 09:42:07, Info CBS Reboot mark set
2016-05-17 09:42:07, Info CBS Winlogon: Registering for CreateSession notifications
2016-05-17 09:42:07, Info CBS Maint: begin archive logs
2016-05-17 09:42:14, Info CBS Archived backup log: C:\windows\Logs\CBS\CbsPersist_20160517154844.cab.
2016-05-17 09:42:14, Info CBS CAB compressed log file: C:\windows\Logs\CBS\CbsPersist_20160517154844.log
2016-05-17 09:42:24, Info CBS Archived backup log: C:\windows\Logs\CBS\CbsPersist_20160517164206.cab.
2016-05-17 09:42:24, Info CBS CAB compressed log file: C:\windows\Logs\CBS\CbsPersist_20160517164206.log
2016-05-17 09:42:24, Info CBS Maint: end archive logs, archive time so far: 16 seconds
2016-05-17 09:42:24, Info CBS Maint: begin scavenge
2016-05-17 09:42:24, Info CBS Scavenge: Start CSI
2016-05-17 09:42:25, Info CSI 00000002 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x88ba9df830
2016-05-17 09:42:25, Info CSI 00000003 Creating NT transaction (seq 1), objec
Harrier
"I tried to do another scan.... nothing, it just sat there. I restarted the PC and tried again and after 10 minutes it was still not doing another scan....... Did I miss something?"
This was TOTALLY my fault........ I missed a step.... SORRY
Scan #2 underway.
Harrier
Scan #2 unsuccessful....
2016-05-17 09:42:25, Info CSI 00000003 Creating NT transaction (seq 1), objectname [6]"(null)"
2016-05-17 09:42:25, Info CSI 00000004 Created NT transaction (seq 1) result 0x00000000, handle @0x294
2016-05-17 09:42:25, Info CSI 00000005 Poqexec successfully registered in [ml:26{13},l:24{12}]"SetupExecute"
2016-05-17 09:42:25, Info CSI 00000006@2016/5/17:16:42:25.507 Beginning NT transaction commit...
2016-05-17 09:42:25, Info CSI 00000007@2016/5/17:16:42:25.507 CSI perf trace:
CSIPERF:TXCOMMIT;5475
2016-05-17 09:42:25, Info CSI 00000008 CSI Store 587231865408 (0x00000088b9bf2a40) initialized
2016-05-17 09:42:25, Info CSI 00000009@2016/5/17:16:42:25.523 CSI Transaction @0x88b9c19560 initialized for deployment engine {d16d444c-56d8-11d5-882d-0080c847b195} with flags 00000002 and client id [10]"TI6.0_0:0/"
2016-05-17 09:42:25, Info CBS Scavenge: Begin CSI Store
2016-05-17 09:42:29, Info CSI 0000000a Performing 1 operations; 1 are not lock/unlock and follow:
(0) Scavenge (8): flags: 00000037
2016-05-17 09:42:29, Info CSI 0000000b Scavenge: Begin processing lists
2016-05-17 09:42:31, Info CSI 0000000c Scavenge: Begin planning
2016-05-17 09:42:50, Info CSI 0000000d Scavenge: Planning Complete.
The following actions will be performed:
Regeneration Candidates: 0
lifetec
Do the DISM commands and run SFC again, see the tutorial.
    windows 8.1
    self build
    Asrock P55 Pro
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    Antec 300
Harrier
Hope you get this OK
OK..... I think my PC bunched them all together... this last file is too big to copy and paste, so I'm hoping an attachment will work...... After all this, I don't have much faith that i will be able to use my system restore again. Just something in my head is telling me that.
Sorry the file was too big for the forum to take
Harrier
OK, I managed to get the last part of the last log. BUT, I did see at the end that windows said it was succesful ... Please let me know
2016-05-17 16:11:27, Info CSI 000007b5 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\fi-FI" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"fi-fi", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:28, Info CSI 000007b6 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sk-SK" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sk-sk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:28, Info CSI 000007b7 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\hu-HU" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"hu-hu", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:28, Info CSI 000007b8 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pt-PT" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pt-pt", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:28, Info CSI 000007b9 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pl-PL" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pl-pl", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:29, Info CSI 000007ba Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\hr-HR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"hr-hr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:29, Info CSI 000007bb Ignoring duplicate ownership for directory [l:68\{34\}]"\\??\\C:\\windows\\SysWOW64\\sr-Latn-CS" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:20\{10\}]"sr-latn-cs", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:29, Info CSI 000007bc Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\es-ES" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"es-es", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:29, Info CSI 000007bd Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ro-RO" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ro-ro", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:30, Info CSI 000007be Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ru-RU" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ru-ru", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:30, Info CSI 000007bf Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sv-SE" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sv-se", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:30, Info CSI 000007c0 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\lv-LV" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"lv-lv", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:31, Info CSI 000007c1 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\lt-LT" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"lt-lt", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:31, Info CSI 000007c2 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ja-JP" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ja-jp", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:32, Info CSI 000007c3 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\he-IL" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"he-il", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:32, Info CSI 000007c4 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\uk-UA" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"uk-ua", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:33, Info CSI 000007c5 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\nb-NO" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"nb-no", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:33, Info CSI 000007c6 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sl-SI" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sl-si", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:34, Info CSI 000007c7 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-US" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:34, Info CSI 000007c8 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-HK" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-hk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:34, Info CSI 000007c9 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-TW" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-tw", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:35, Info CSI 000007ca Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-CN" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-cn", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:35, Info CSI 000007cb Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pt-BR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pt-br", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:35, Info CSI 000007cc Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\el-GR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"el-gr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:36, Info CSI 000007cd Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ko-KR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ko-kr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:36, Info CSI 000007ce [DIRSD OWNER WARNING] Directory [ml:64\{32\},l:62\{31\}]"\\??\\C:\\windows\\SysWOW64\\catroot" is not owned but specifies SDDL in component Microsoft-Windows-CryptBase, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:36, Info CSI 000007cf [DIRSD OWNER WARNING] Directory [ml:142\{71\},l:140\{70\}]"\\??\\C:\\windows\\SysWOW64\\catroot\\\{F750E6C3-38EE-11D1-85E5-00C04FC295EE\}" is not owned but specifies SDDL in component Microsoft-Windows-CryptBase, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:37, Info CSI 000007d0 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-GB" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-gb", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:37, Info CSI 000007d1 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\th-TH" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"th-th", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:38, Info CSI 000007d2 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\tr-TR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"tr-tr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:38, Info CSI 000007d3 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\et-EE" in component Microsoft-Windows-comdlg32.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"et-ee", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:38, Info CSI 000007d4 [SR] Verify complete\par
2016-05-17 16:11:39, Info CSI 000007d5 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:11:39, Info CSI 000007d6 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:11:45, Info CSI 000007d7 [DIRSD OWNER WARNING] Directory [ml:126\{63\},l:124\{62\}]"\\??\\C:\\windows\\SysWOW64\\WindowsPowerShell\\v1.0\\Modules\\Dism\\en" is not owned but specifies SDDL in component Microsoft-Windows-Deployment-Image-Servicing-Management-Powershell.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:47, Info CSI 000007d8 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:60\{30\}]"\\??\\C:\\windows\\InputMethod\\JPN" is not owned but specifies SDDL in component Microsoft-Windows-Desktop_Technologies-Text_Input_Services-IME-Japanese-DirectorySetup, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:47, Info CSI 000007d9 [DIRSD OWNER WARNING] Directory [ml:80\{40\},l:78\{39\}]"\\??\\C:\\windows\\SysWOW64\\InputMethod\\JPN" is not owned but specifies SDDL in component Microsoft-Windows-Desktop_Technologies-Text_Input_Services-IME-Japanese-DirectorySetup, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:47, Info CSI 000007da Ignoring duplicate ownership for directory [l:60\{30\}]"\\??\\C:\\windows\\InputMethod\\JPN" in component Microsoft-Windows-Desktop_Technologies-Text_Input_Services-IME-Japanese-DirectorySetup, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:48, Info CSI 000007db [DIRSD OWNER WARNING] Directory [ml:120\{60\},l:118\{59\}]"\\??\\C:\\windows\\SysWOW64\\WindowsPowerShell\\v1.0\\Modules\\Dism" is not owned but specifies SDDL in component Microsoft-Windows-Deployment-Image-Servicing-Management-Powershell, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:49, Info CSI 000007dc [SR] Verify complete\par
2016-05-17 16:11:50, Info CSI 000007dd [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:11:50, Info CSI 000007de [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:11:56, Info CSI 000007df [DIRSD OWNER WARNING] Directory [ml:130\{65\},l:128\{64\}]"\\??\\C:\\windows\\SysWOW64\\WindowsPowerShell\\v1.0\\Modules\\DnsClient" is not owned but specifies SDDL in component Microsoft-Windows-DNS-Client-Lookup-PowerShell, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:11:56, Info CSI 000007e0 Ignoring duplicate ownership for directory [l:128\{64\}]"\\??\\C:\\windows\\SysWOW64\\WindowsPowerShell\\v1.0\\Modules\\DnsClient" in component Microsoft-Windows-DNS-Client-Lookup-PowerShell, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:00, Info CSI 000007e1 [SR] Verify complete\par
2016-05-17 16:12:01, Info CSI 000007e2 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:12:01, Info CSI 000007e3 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:12:10, Info CSI 000007e4 [DIRSD OWNER WARNING] Directory [ml:72\{36\},l:70\{35\}]"\\??\\C:\\windows\\SysWOW64\\DriverStore" is not owned but specifies SDDL in component Microsoft-Windows-DrvStore, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:11, Info CSI 000007e5 [DIRSD OWNER WARNING] Directory [ml:154\{77\},l:152\{76\}]"\\??\\C:\\windows\\SysWOW64\\WindowsPowerShell\\v1.0\\Modules\\WindowsErrorReporting" is not owned but specifies SDDL in component Microsoft-Windows-ErrorReportingPowershell, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:12, Info CSI 000007e6 [SR] Verify complete\par
2016-05-17 16:12:13, Info CSI 000007e7 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:12:13, Info CSI 000007e8 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:12:17, Info CSI 000007e9 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\cs-CZ" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"cs-cz", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:17, Info CSI 000007ea [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:104\{52\}]"\\??\\C:\\ProgramData\\Microsoft\\Windows\\WER\\ReportQueue" is not owned but specifies SDDL in component Microsoft-Windows-ErrorReportingCore, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:17, Info CSI 000007eb [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:108\{54\}]"\\??\\C:\\ProgramData\\Microsoft\\Windows\\WER\\ReportArchive" is not owned but specifies SDDL in component Microsoft-Windows-ErrorReportingCore, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:17, Info CSI 000007ec [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:64\{32\}]"\\??\\C:\\windows\\LiveKernelReports" is not owned but specifies SDDL in component Microsoft-Windows-ErrorReportingCore, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:17, Info CSI 000007ed Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pt-BR" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pt-br", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:18, Info CSI 000007ee Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\it-IT" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"it-it", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:19, Info CSI 000007ef Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\es-ES" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"es-es", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:19, Info CSI 000007f0 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\he-IL" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"he-il", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:20, Info CSI 000007f1 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\et-EE" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"et-ee", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:20, Info CSI 000007f2 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-GB" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-gb", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:21, Info CSI 000007f3 Ignoring duplicate ownership for directory [l:70\{35\}]"\\??\\C:\\windows\\SysWOW64\\setup\\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:21, Info CSI 000007f4 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:21, Info CSI 000007f5 Ignoring duplicate ownership for directory [l:84\{42\}]"\\??\\C:\\windows\\Resources\\Themes\\aero\\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:22, Info CSI 000007f6 Ignoring duplicate ownership for directory [l:104\{52\}]"\\??\\C:\\Program Files (x86)\\Common Files\\System\\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:22, Info CSI 000007f7 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ja-JP" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ja-jp", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:22, Info CSI 000007f8 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\nl-NL" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"nl-nl", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:23, Info CSI 000007f9 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\hu-HU" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"hu-hu", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:23, Info CSI 000007fa Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pl-PL" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pl-pl", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:24, Info CSI 000007fb Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\de-DE" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"de-de", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:24, Info CSI 000007fc Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\lt-LT" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"lt-lt", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:25, Info CSI 000007fd Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\lv-LV" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"lv-lv", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:25, Info CSI 000007fe Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\el-GR" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"el-gr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:25, Info CSI 000007ff Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ar-SA" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ar-sa", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:26, Info CSI 00000800 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\fi-FI" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"fi-fi", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:26, Info CSI 00000801 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\fr-FR" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"fr-fr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:26, Info CSI 00000802 Ignoring duplicate ownership for directory [l:52\{26\}]"\\??\\C:\\Program Files (x86)" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:27, Info CSI 00000803 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\setup" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:27, Info CSI 00000804 Ignoring duplicate ownership for directory [l:62\{31\}]"\\??\\C:\\windows\\system32\\drivers" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:28, Info CSI 00000805 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\da-DK" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"da-dk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:28, Info CSI 00000806 [SR] Verify complete\par
2016-05-17 16:12:28, Info CSI 00000807 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:12:28, Info CSI 00000808 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:12:32, Info CSI 00000809 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ar-SA" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ar-sa", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:32, Info CSI 0000080a Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-CN" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-cn", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:32, Info CSI 0000080b Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-HK" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-hk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:34, Info CSI 0000080c Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-TW" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-tw", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:35, Info CSI 0000080d Ignoring duplicate ownership for directory [l:68\{34\}]"\\??\\C:\\windows\\SysWOW64\\sr-Latn-RS" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:20\{10\}]"sr-latn-rs", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:35, Info CSI 0000080e Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\tr-TR" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"tr-tr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:36, Info CSI 0000080f Ignoring duplicate ownership for directory [l:68\{34\}]"\\??\\C:\\windows\\SysWOW64\\sr-Latn-CS" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:20\{10\}]"sr-latn-cs", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:36, Info CSI 00000810 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sl-SI" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sl-si", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:36, Info CSI 00000811 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pt-PT" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pt-pt", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:37, Info CSI 00000812 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ro-RO" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ro-ro", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:37, Info CSI 00000813 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\uk-UA" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"uk-ua", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:38, Info CSI 00000814 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sv-SE" in component Microsoft-Windows-Font-FMS.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sv-se", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:10\{5\}]"win32", TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:39, Info CSI 00000815 [SR] Verify complete\par
2016-05-17 16:12:39, Info CSI 00000816 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:12:39, Info CSI 00000817 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:12:42, Info CSI 00000818 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\nb-NO" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"nb-no", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:43, Info CSI 00000819 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-US" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:44, Info CSI 0000081a Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pt-BR" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pt-br", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:45, Info CSI 0000081b Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ko-KR" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ko-kr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:45, Info CSI 0000081c Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\da-DK" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"da-dk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:46, Info CSI 0000081d Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-GB" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-gb", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:46, Info CSI 0000081e Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ru-RU" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ru-ru", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:46, Info CSI 0000081f Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ro-RO" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ro-ro", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:47, Info CSI 00000820 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\th-TH" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"th-th", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:47, Info CSI 00000821 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\lv-LV" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"lv-lv", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:48, Info CSI 00000822 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\et-EE" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"et-ee", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:48, Info CSI 00000823 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\it-IT" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"it-it", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:49, Info CSI 00000824 Ignoring duplicate ownership for directory [l:82\{41\}]"\\??\\C:\\windows\\SysWOW64\\IME\\IMETC\\Applets" in component Microsoft-Windows-IME-Traditional-Chinese-IMEPadApplet, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:50, Info CSI 00000825 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sk-SK" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sk-sk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:50, Info CSI 00000826 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\hr-HR" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"hr-hr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:50, Info CSI 00000827 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\hu-HU" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"hu-hu", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:51, Info CSI 00000828 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\es-ES" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"es-es", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:51, Info CSI 00000829 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\bg-BG" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"bg-bg", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:53, Info CSI 0000082a Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sv-SE" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sv-se", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:53, Info CSI 0000082b Ignoring duplicate ownership for directory [l:68\{34\}]"\\??\\C:\\windows\\SysWOW64\\sr-Latn-RS" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:20\{10\}]"sr-latn-rs", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:53, Info CSI 0000082c Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-HK" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-hk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:12:54, Info CSI 0000082d [SR] Verify complete\par
2016-05-17 16:12:55, Info CSI 0000082e [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:12:55, Info CSI 0000082f [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:13:01, Info CSI 00000830 [SR] Verify complete\par
2016-05-17 16:13:01, Info CSI 00000831 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:13:01, Info CSI 00000832 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:13:13, Info CSI 00000833 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:98\{49\}]"\\??\\C:\\Program Files (x86)\\Internet Explorer\\pris" is not owned but specifies SDDL in component Microsoft-Windows-ImmersiveBrowser.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:14, Info CSI 00000834 [DIRSD OWNER WARNING] Directory [ml:68\{34\},l:66\{33\}]"\\??\\C:\\windows\\SysWOW64\\IME\\IMEKR" is not owned but specifies SDDL in component Microsoft-Windows-IME-Korean-Core, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:14, Info CSI 00000835 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:60\{30\}]"\\??\\C:\\windows\\IME\\IMEKR\\DICTS" is not owned but specifies SDDL in component Microsoft-Windows-IME-Korean-Core, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:14, Info CSI 00000836 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:48\{24\}]"\\??\\C:\\windows\\IME\\IMEKR" is not owned but specifies SDDL in component Microsoft-Windows-IME-Korean-Core, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:14, Info CSI 00000837 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:58\{29\}]"\\??\\C:\\windows\\IME\\IMEKR\\HELP" is not owned but specifies SDDL in component Microsoft-Windows-IME-Korean-Core, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:14, Info CSI 00000838 [DIRSD OWNER WARNING] Directory [ml:80\{40\},l:78\{39\}]"\\??\\C:\\windows\\SysWOW64\\IME\\IMEKR\\DICTS" is not owned but specifies SDDL in component Microsoft-Windows-IME-Korean-Core, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:14, Info CSI 00000839 [DIRSD OWNER WARNING] Directory [ml:84\{42\},l:82\{41\}]"\\??\\C:\\windows\\SysWOW64\\IME\\IMEKR\\APPLETS" is not owned but specifies SDDL in component Microsoft-Windows-IME-Korean-Core, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:14, Info CSI 0000083a Ignoring duplicate ownership for directory [l:78\{39\}]"\\??\\C:\\windows\\SysWOW64\\IME\\IMEKR\\DICTS" in component Microsoft-Windows-IME-Korean-Core, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:15, Info CSI 0000083b [SR] Verify complete\par
2016-05-17 16:13:15, Info CSI 0000083c [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:13:15, Info CSI 0000083d [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:13:18, Info CSI 0000083e Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-CN" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-cn", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:18, Info CSI 0000083f Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-HK" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-hk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:18, Info CSI 00000840 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-TW" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-tw", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:19, Info CSI 00000841 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\he-IL" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"he-il", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:19, Info CSI 00000842 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\nb-NO" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"nb-no", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:20, Info CSI 00000843 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-US" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:21, Info CSI 00000844 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pt-BR" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pt-br", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:21, Info CSI 00000845 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\el-GR" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"el-gr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:21, Info CSI 00000846 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:56\{28\}]"\\??\\C:\\windows\\Globalization" is not owned but specifies SDDL in component Microsoft-Windows-International-Core, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:22, Info CSI 00000847 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ko-KR" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ko-kr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:22, Info CSI 00000848 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\da-DK" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"da-dk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:23, Info CSI 00000849 [DIRSD OWNER WARNING] Directory [ml:58\{29\},l:56\{28\}]"\\??\\C:\\windows\\SysWOW64\\Ipmi" is not owned but specifies SDDL in component Microsoft-Windows-IPMIProvider, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:24, Info CSI 0000084a Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ru-RU" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ru-ru", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:24, Info CSI 0000084b Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\de-DE" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"de-de", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:25, Info CSI 0000084c Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\tr-TR" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"tr-tr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:25, Info CSI 0000084d Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\it-IT" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"it-it", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:25, Info CSI 0000084e [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:90\{45\}]"\\??\\C:\\Program Files (x86)\\Windows Mail\\en-US" is not owned but specifies SDDL in component Microsoft-Windows-Mail-Core-DLL.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:26, Info CSI 0000084f Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\fi-FI" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"fi-fi", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:26, Info CSI 00000850 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\fr-FR" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"fr-fr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:26, Info CSI 00000851 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\nl-NL" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"nl-nl", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:26, Info CSI 00000852 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ja-JP" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ja-jp", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:27, Info CSI 00000853 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\hu-HU" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"hu-hu", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:27, Info CSI 00000854 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pl-PL" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pl-pl", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:27, Info CSI 00000855 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pt-PT" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pt-pt", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:28, Info CSI 00000856 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\cs-CZ" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"cs-cz", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:28, Info CSI 00000857 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sv-SE" in component Microsoft-Windows-LSA-MSPrivs.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sv-se", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:29, Info CSI 00000858 [SR] Verify complete\par
2016-05-17 16:13:29, Info CSI 00000859 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:13:29, Info CSI 0000085a [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:13:39, Info CSI 0000085b [SR] Verify complete\par
2016-05-17 16:13:39, Info CSI 0000085c [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:13:39, Info CSI 0000085d [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:13:43, Info CSI 0000085e [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:94\{47\}]"\\??\\C:\\Program Files (x86)\\Windows Media Player" is not owned but specifies SDDL in component Microsoft-Windows-MediaPlayer-Common, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:44, Info CSI 0000085f Ignoring duplicate ownership for directory [l:94\{47\}]"\\??\\C:\\Program Files (x86)\\Windows Media Player" in component Microsoft-Windows-MediaPlayer-Common, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:45, Info CSI 00000860 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:90\{45\}]"\\??\\C:\\Program Files (x86)\\Windows Mail\\en-US" is not owned but specifies SDDL in component Microsoft-Windows-Mail-App.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:45, Info CSI 00000861 Ignoring duplicate ownership for directory [l:90\{45\}]"\\??\\C:\\Program Files (x86)\\Windows Mail\\en-US" in component Microsoft-Windows-Mail-App.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:47, Info CSI 00000862 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:120\{60\}]"\\??\\C:\\Program Files (x86)\\Common Files\\Microsoft Shared\\DAO" is not owned but specifies SDDL in component Microsoft-Windows-Microsoft-Data-Access-Components-JetDAO, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:13:48, Info CSI 00000863 [SR] Verify complete\par
2016-05-17 16:13:49, Info CSI 00000864 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:13:49, Info CSI 00000865 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:14:00, Info CSI 00000866 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sk-SK" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sk-sk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:00, Info CSI 00000867 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\hr-HR" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"hr-hr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:01, Info CSI 00000868 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pl-PL" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pl-pl", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:01, Info CSI 00000869 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\pt-PT" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"pt-pt", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:01, Info CSI 0000086a Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\es-ES" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"es-es", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:02, Info CSI 0000086b Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\bg-BG" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"bg-bg", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:02, Info CSI 0000086c Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ru-RU" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ru-ru", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:03, Info CSI 0000086d Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\de-DE" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"de-de", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:03, Info CSI 0000086e Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\lt-LT" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"lt-lt", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:03, Info CSI 0000086f Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\th-TH" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"th-th", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:04, Info CSI 00000870 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\tr-TR" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"tr-tr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:04, Info CSI 00000871 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\it-IT" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"it-it", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:04, Info CSI 00000872 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\fi-FI" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"fi-fi", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:04, Info CSI 00000873 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\fr-FR" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"fr-fr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:05, Info CSI 00000874 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\nl-NL" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"nl-nl", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:05, Info CSI 00000875 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ja-JP" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ja-jp", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:05, Info CSI 00000876 Ignoring duplicate ownership for directory [l:68\{34\}]"\\??\\C:\\windows\\SysWOW64\\sr-Latn-CS" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:20\{10\}]"sr-latn-cs", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:06, Info CSI 00000877 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\he-IL" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"he-il", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:06, Info CSI 00000878 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\uk-UA" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"uk-ua", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:06, Info CSI 00000879 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\cs-CZ" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"cs-cz", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:07, Info CSI 0000087a Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\sl-SI" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"sl-si", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:07, Info CSI 0000087b Ignoring duplicate ownership for directory [l:68\{34\}]"\\??\\C:\\windows\\SysWOW64\\sr-Latn-RS" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:20\{10\}]"sr-latn-rs", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:08, Info CSI 0000087c Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-US" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:08, Info CSI 0000087d Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-CN" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-cn", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:08, Info CSI 0000087e Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\zh-TW" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"zh-tw", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:09, Info CSI 0000087f Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ar-SA" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ar-sa", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:10, Info CSI 00000880 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\el-GR" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"el-gr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:10, Info CSI 00000881 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\nb-NO" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"nb-no", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:12, Info CSI 00000882 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\ko-KR" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"ko-kr", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:13, Info CSI 00000883 Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\da-DK" in component Microsoft-Windows-mlang.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"da-dk", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:13, Info CSI 00000884 [SR] Verify complete\par
2016-05-17 16:14:13, Info CSI 00000885 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:14:13, Info CSI 00000886 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:14:19, Info CSI 00000887 [DIRSD OWNER WARNING] Directory [ml:56\{28\},l:54\{27\}]"\\??\\C:\\windows\\SysWOW64\\NDF" is not owned but specifies SDDL in component Microsoft-Windows-NetworkDiagnosticsFrameworkSettings, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:22, Info CSI 00000888 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:62\{31\}]"\\??\\C:\\windows\\rescache\\_merged" is not owned but specifies SDDL in component Microsoft-Windows-MUI-Settings, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:22, Info CSI 00000889 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:46\{23\}]"\\??\\C:\\windows\\rescache" is not owned but specifies SDDL in component Microsoft-Windows-MUI-Settings, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:22, Info CSI 0000088a Ignoring duplicate ownership for directory [l:46\{23\}]"\\??\\C:\\windows\\rescache" in component Microsoft-Windows-MUI-Settings, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:22, Info CSI 0000088b Ignoring duplicate ownership for directory [l:62\{31\}]"\\??\\C:\\windows\\rescache\\_merged" in component Microsoft-Windows-MUI-Settings, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:23, Info CSI 0000088c [SR] Verify complete\par
2016-05-17 16:14:23, Info CSI 0000088d [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:14:23, Info CSI 0000088e [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:14:39, Info CSI 0000088f [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:116\{58\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\MUI\\0409" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000890 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:96\{48\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v1.0.3705" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000891 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:86\{43\}]"\\??\\C:\\windows\\Inf\\.NET CLR Networking\\0000" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000892 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:112\{56\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\CONFIG" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000893 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:112\{56\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for SqlServer\\0000" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000894 [DIRSD OWNER WARNING] Directory [ml:66\{33\},l:64\{32\}]"\\??\\C:\\windows\\SysWOW64\\MUI\\0409" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000895 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:102\{51\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for SqlServer" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000896 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:96\{48\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for Oracle" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000897 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:106\{53\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for Oracle\\0000" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000898 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:74\{37\}]"\\??\\C:\\windows\\Inf\\.NET CLR Data\\0000" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 00000899 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:76\{38\}]"\\??\\C:\\windows\\Inf\\.NET CLR Networking" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 0000089a [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:64\{32\}]"\\??\\C:\\windows\\Inf\\.NETFramework" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 0000089b [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:98\{49\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 0000089c [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:76\{38\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 0000089d [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:74\{37\}]"\\??\\C:\\windows\\Inf\\.NETFramework\\0000" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 0000089e [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:108\{54\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\1033" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 0000089f [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:64\{32\}]"\\??\\C:\\windows\\Inf\\.NET CLR Data" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a0 Ignoring duplicate ownership for directory [l:76\{38\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a1 Ignoring duplicate ownership for directory [l:98\{49\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a2 Ignoring duplicate ownership for directory [l:112\{56\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\CONFIG" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a3 Ignoring duplicate ownership for directory [l:96\{48\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v1.0.3705" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a4 Ignoring duplicate ownership for directory [l:64\{32\}]"\\??\\C:\\windows\\SysWOW64\\MUI\\0409" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a5 Ignoring duplicate ownership for directory [l:64\{32\}]"\\??\\C:\\windows\\Inf\\.NET CLR Data" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a6 Ignoring duplicate ownership for directory [l:74\{37\}]"\\??\\C:\\windows\\Inf\\.NET CLR Data\\0000" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a7 Ignoring duplicate ownership for directory [l:76\{38\}]"\\??\\C:\\windows\\Inf\\.NET CLR Networking" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a8 Ignoring duplicate ownership for directory [l:86\{43\}]"\\??\\C:\\windows\\Inf\\.NET CLR Networking\\0000" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008a9 Ignoring duplicate ownership for directory [l:96\{48\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for Oracle" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008aa Ignoring duplicate ownership for directory [l:106\{53\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for Oracle\\0000" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008ab Ignoring duplicate ownership for directory [l:102\{51\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for SqlServer" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008ac Ignoring duplicate ownership for directory [l:112\{56\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for SqlServer\\0000" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008ad Ignoring duplicate ownership for directory [l:64\{32\}]"\\??\\C:\\windows\\Inf\\.NETFramework" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008ae Ignoring duplicate ownership for directory [l:74\{37\}]"\\??\\C:\\windows\\Inf\\.NETFramework\\0000" in component Microsoft-Windows-NETFXCoreComp, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008af [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:86\{43\}]"\\??\\C:\\windows\\Inf\\.NET CLR Networking\\0409" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008b0 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:112\{56\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for SqlServer\\0409" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008b1 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:106\{53\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for Oracle\\0409" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008b2 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:74\{37\}]"\\??\\C:\\windows\\Inf\\.NET CLR Data\\0409" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008b3 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:74\{37\}]"\\??\\C:\\windows\\Inf\\.NETFramework\\0409" is not owned but specifies SDDL in component Microsoft-Windows-NETFXCoreComp.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008b4 Ignoring duplicate ownership for directory [l:74\{37\}]"\\??\\C:\\windows\\Inf\\.NET CLR Data\\0409" in component Microsoft-Windows-NETFXCoreComp.Resources, Version = 6.3.9600.17226, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008b5 Ignoring duplicate ownership for directory [l:86\{43\}]"\\??\\C:\\windows\\Inf\\.NET CLR Networking\\0409" in component Microsoft-Windows-NETFXCoreComp.Resources, Version = 6.3.9600.17226, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008b6 Ignoring duplicate ownership for directory [l:106\{53\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for Oracle\\0409" in component Microsoft-Windows-NETFXCoreComp.Resources, Version = 6.3.9600.17226, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008b7 Ignoring duplicate ownership for directory [l:112\{56\}]"\\??\\C:\\windows\\Inf\\.NET Data Provider for SqlServer\\0409" in component Microsoft-Windows-NETFXCoreComp.Resources, Version = 6.3.9600.17226, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:39, Info CSI 000008b8 Ignoring duplicate ownership for directory [l:74\{37\}]"\\??\\C:\\windows\\Inf\\.NETFramework\\0409" in component Microsoft-Windows-NETFXCoreComp.Resources, Version = 6.3.9600.17226, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:14:46, Info CSI 000008b9 [SR] Verify complete\par
2016-05-17 16:14:46, Info CSI 000008ba [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:14:46, Info CSI 000008bb [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:14:55, Info CSI 000008bc [SR] Verify complete\par
2016-05-17 16:14:55, Info CSI 000008bd [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:14:55, Info CSI 000008be [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:15:01, Info CSI 000008bf [DIRSD OWNER WARNING] Directory [ml:90\{45\},l:88\{44\}]"\\??\\C:\\windows\\SysWOW64\\config\\systemprofile" is not owned but specifies SDDL in component Microsoft-Windows-Profapi, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:01, Info CSI 000008c0 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:36\{18\}]"\\??\\C:\\ProgramData" is not owned but specifies SDDL in component Microsoft-Windows-Profapi, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:01, Info CSI 000008c1 Ignoring duplicate ownership for directory [l:36\{18\}]"\\??\\C:\\ProgramData" in component Microsoft-Windows-Profapi, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:01, Info CSI 000008c2 Ignoring duplicate ownership for directory [l:24\{12\}]"\\??\\C:\\Users" in component Microsoft-Windows-Profapi, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:01, Info CSI 000008c3 Ignoring duplicate ownership for directory [l:38\{19\}]"\\??\\C:\\Users\\Public" in component Microsoft-Windows-Profapi, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:01, Info CSI 000008c4 Ignoring duplicate ownership for directory [l:40\{20\}]"\\??\\C:\\Users\\Default" in component Microsoft-Windows-Profapi, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:01, Info CSI 000008c5 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:94\{47\}]"\\??\\C:\\Program Files (x86)\\Windows Photo Viewer" is not owned but specifies SDDL in component Microsoft-Windows-Photo-Common, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:04, Info CSI 000008c6 [DIRSD OWNER WARNING] Directory [ml:142\{71\},l:140\{70\}]"\\??\\C:\\windows\\SysWOW64\\WindowsPowerShell\\v1.0\\Modules\\PrintManagement" is not owned but specifies SDDL in component Microsoft-Windows-Printing-PowerShell, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:04, Info CSI 000008c7 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:74\{37\}]"\\??\\C:\\ProgramData\\Microsoft\\RAC\\Temp" is not owned but specifies SDDL in component Microsoft-Windows-ReliabilityAnalysisConfig, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:04, Info CSI 000008c8 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:82\{41\}]"\\??\\C:\\ProgramData\\Microsoft\\RAC\\Outbound" is not owned but specifies SDDL in component Microsoft-Windows-ReliabilityAnalysisConfig, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:04, Info CSI 000008c9 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:84\{42\}]"\\??\\C:\\ProgramData\\Microsoft\\RAC\\StateData" is not owned but specifies SDDL in component Microsoft-Windows-ReliabilityAnalysisConfig, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:04, Info CSI 000008ca Ignoring duplicate ownership for directory [l:82\{41\}]"\\??\\C:\\ProgramData\\Microsoft\\RAC\\Outbound" in component Microsoft-Windows-ReliabilityAnalysisConfig, Version = 6.3.9600.17031, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:04, Info CSI 000008cb Ignoring duplicate ownership for directory [l:74\{37\}]"\\??\\C:\\ProgramData\\Microsoft\\RAC\\Temp" in component Microsoft-Windows-ReliabilityAnalysisConfig, Version = 6.3.9600.17031, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:04, Info CSI 000008cc Ignoring duplicate ownership for directory [l:84\{42\}]"\\??\\C:\\ProgramData\\Microsoft\\RAC\\StateData" in component Microsoft-Windows-ReliabilityAnalysisConfig, Version = 6.3.9600.17031, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:05, Info CSI 000008cd [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:78\{39\}]"\\??\\C:\\ProgramData\\Microsoft\\DRM\\Server" is not owned but specifies SDDL in component Microsoft-Windows-Rights-Management-Client-v1-API, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:05, Info CSI 000008ce Ignoring duplicate ownership for directory [l:78\{39\}]"\\??\\C:\\ProgramData\\Microsoft\\DRM\\Server" in component Microsoft-Windows-Rights-Management-Client-v1-API, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:05, Info CSI 000008cf [SR] Verify complete\par
2016-05-17 16:15:06, Info CSI 000008d0 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:15:06, Info CSI 000008d1 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:15:10, Info CSI 000008d2 Ignoring duplicate ownership for directory [l:44\{22\}]"\\??\\C:\\windows\\tracing" in component Microsoft-Windows-RasRTUtils, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:10, Info CSI 000008d3 Ignoring duplicate ownership for directory [l:40\{20\}]"\\??\\C:\\sources\\en-US" in component Microsoft-Windows-SKU-Foundation-Extra-Security.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:10, Info CSI 000008d4 Ignoring duplicate ownership for directory [l:66\{33\}]"\\??\\C:\\sources\\etwproviders\\en-US" in component Microsoft-Windows-SKU-Foundation-Extra-Security.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:14, Info CSI 000008d5 [SR] Verify complete\par
2016-05-17 16:15:15, Info CSI 000008d6 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:15:15, Info CSI 000008d7 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:15:22, Info CSI 000008d8 [DIRSD OWNER WARNING] Directory [ml:80\{40\},l:78\{39\}]"\\??\\C:\\windows\\SysWOW64\\Speech\\SpeechUX" is not owned but specifies SDDL in component Microsoft-Windows-Speech-UserExperience-Common, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:23, Info CSI 000008d9 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:64\{32\}]"\\??\\C:\\windows\\Diagnostics\\index" is not owned but specifies SDDL in component Microsoft-Windows-ScriptedDiagnosticsProvider-Library, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:23, Info CSI 000008da [SR] Verify complete\par
2016-05-17 16:15:24, Info CSI 000008db [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:15:24, Info CSI 000008dc [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:15:30, Info CSI 000008dd [DIRSD OWNER WARNING] Directory [ml:60\{30\},l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-US" is not owned but specifies SDDL in component Microsoft-Windows-SFC.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:30, Info CSI 000008de Ignoring duplicate ownership for directory [l:58\{29\}]"\\??\\C:\\windows\\SysWOW64\\en-US" in component Microsoft-Windows-SFC.Resources, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:31, Info CSI 000008df [DIRSD OWNER WARNING] Directory [ml:78\{39\},l:76\{38\}]"\\??\\C:\\windows\\SysWOW64\\wdi\\SleepStudy" is not owned but specifies SDDL in component Microsoft-Windows-SleepStudy-Troubleshooter, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:35, Info CSI 000008e0 [SR] Verify complete\par
2016-05-17 16:15:35, Info CSI 000008e1 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:15:35, Info CSI 000008e2 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:15:40, Info CSI 000008e3 [DIRSD OWNER WARNING] Directory [ml:76\{38\},l:74\{37\}]"\\??\\C:\\windows\\SysWOW64\\Speech\\Common" is not owned but specifies SDDL in component Microsoft-Windows-SpeechCommon, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:41, Info CSI 000008e4 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:66\{33\}]"\\??\\C:\\windows\\winsxs\\InstallTemp" is not owned but specifies SDDL in component Microsoft-Windows-Sxs, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:41, Info CSI 000008e5 Ignoring duplicate ownership for directory [l:66\{33\}]"\\??\\C:\\windows\\winsxs\\InstallTemp" in component Microsoft-Windows-Sxs, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:43, Info CSI 000008e6 [DIRSD OWNER WARNING] Directory [ml:56\{28\},l:54\{27\}]"\\??\\C:\\windows\\SysWOW64\\sru" is not owned but specifies SDDL in component Microsoft-Windows-SruMon, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:44, Info CSI 000008e7 [DIRSD OWNER WARNING] Directory [ml:84\{42\},l:82\{41\}]"\\??\\C:\\windows\\SysWOW64\\Speech\\Engines\\SR" is not owned but specifies SDDL in component Microsoft-Windows-SpeechEngine, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:46, Info CSI 000008e8 [SR] Verify complete\par
2016-05-17 16:15:46, Info CSI 000008e9 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:15:46, Info CSI 000008ea [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:15:52, Info CSI 000008eb [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:40\{20\}]"\\??\\C:\\windows\\Tasks" is not owned but specifies SDDL in component Microsoft-Windows-TaskScheduler-Compatibility, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:56, Info CSI 000008ec Ignoring duplicate ownership for directory [l:120\{60\}]"\\??\\C:\\Program Files (x86)\\Common Files\\Microsoft Shared\\Ink" in component Microsoft-Windows-TabletPC-Platform-COMRuntime, Version = 6.3.9600.18261, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:15:56, Info CSI 000008ed [SR] Verify complete\par
2016-05-17 16:15:57, Info CSI 000008ee [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:15:57, Info CSI 000008ef [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:16:02, Info CSI 000008f0 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:38\{19\}]"\\??\\C:\\windows\\TAPI" is not owned but specifies SDDL in component Microsoft-Windows-TapiService, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:04, Info CSI 000008f1 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:48\{24\}]"\\??\\C:\\windows\\ModemLogs" is not owned but specifies SDDL in component Microsoft-Windows-Unimodem-Core-ATMini, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:06, Info CSI 000008f2 [SR] Verify complete\par
2016-05-17 16:16:06, Info CSI 000008f3 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:16:06, Info CSI 000008f4 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:16:15, Info CSI 000008f5 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:100\{50\}]"\\??\\C:\\ProgramData\\Microsoft\\User Account Pictures" is not owned but specifies SDDL in component Microsoft-Windows-usercpl, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:15, Info CSI 000008f6 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:88\{44\}]"\\??\\C:\\windows\\Resources\\Themes\\aero\\VSCache" is not owned but specifies SDDL in component Microsoft-Windows-UXInit, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:15, Info CSI 000008f7 Ignoring duplicate ownership for directory [l:88\{44\}]"\\??\\C:\\windows\\Resources\\Themes\\aero\\VSCache" in component Microsoft-Windows-UXInit, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:16, Info CSI 000008f8 [SR] Verify complete\par
2016-05-17 16:16:16, Info CSI 000008f9 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:16:16, Info CSI 000008fa [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:16:21, Info CSI 000008fb [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:104\{52\}]"\\??\\C:\\Program Files (x86)\\Common Files\\System\\en-US" is not owned but specifies SDDL in component Microsoft-Windows-WAB-Core.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:21, Info CSI 000008fc [DIRSD OWNER WARNING] Directory [ml:66\{33\},l:64\{32\}]"\\??\\C:\\windows\\SysWOW64\\Recovery" is not owned but specifies SDDL in component Microsoft-Windows-WinRE-ReAgentConfig, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:26, Info CSI 000008fd [SR] Verify complete\par
2016-05-17 16:16:26, Info CSI 000008fe [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:16:26, Info CSI 000008ff [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:16:34, Info CSI 00000900 [DIRSD OWNER WARNING] Directory [ml:128\{64\},l:126\{63\}]"\\??\\C:\\windows\\SysWOW64\\WindowsPowerShell\\v1.0\\Modules\\MsDtc\\en" is not owned but specifies SDDL in component Microsoft.Dtc.PowerShell.Non_msil.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:35, Info CSI 00000901 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:118\{59\}]"\\??\\C:\\windows\\Inf\\Windows Workflow Foundation 3.0.0.0\\0409" is not owned but specifies SDDL in component Microsoft-Windows-WWFCoreComp.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:36, Info CSI 00000902 [DIRSD OWNER WARNING] Directory [ml:134\{67\},l:132\{66\}]"\\??\\C:\\windows\\SysWOW64\\WindowsPowerShell\\v1.0\\Modules\\MsDtc\\en-US" is not owned but specifies SDDL in component Microsoft.Dtc.PowerShell.Scripts.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:36, Info CSI 00000903 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:134\{67\}]"\\??\\C:\\Program Files (x86)\\Reference Assemblies\\Microsoft\\Framework" is not owned but specifies SDDL in component Microsoft-Windows-WWFCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:36, Info CSI 00000904 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:118\{59\}]"\\??\\C:\\windows\\Inf\\Windows Workflow Foundation 3.0.0.0\\0000" is not owned but specifies SDDL in component Microsoft-Windows-WWFCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:36, Info CSI 00000905 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:114\{57\}]"\\??\\C:\\Program Files (x86)\\Reference Assemblies\\Microsoft" is not owned but specifies SDDL in component Microsoft-Windows-WWFCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:36, Info CSI 00000906 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:144\{72\}]"\\??\\C:\\Program Files (x86)\\Reference Assemblies\\Microsoft\\Framework\\v3.0" is not owned but specifies SDDL in component Microsoft-Windows-WWFCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:36, Info CSI 00000907 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:94\{47\}]"\\??\\C:\\Program Files (x86)\\Reference Assemblies" is not owned but specifies SDDL in component Microsoft-Windows-WWFCoreComp, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:38, Info CSI 00000908 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:106\{53\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v3.0\\WPF\\en-US" is not owned but specifies SDDL in component Microsoft-Windows-WPFCoreComp.Resources, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10\{5\}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:38, Info CSI 00000909 Ignoring duplicate ownership for directory [l:72\{36\}]"\\??\\C:\\windows\\microsoft.net\\authman" in component Microsoft.Interop.Security.AzRoles, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:16:39, Info CSI 0000090a [SR] Verify complete\par
2016-05-17 16:16:40, Info CSI 0000090b [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:16:40, Info CSI 0000090c [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:16:48, Info CSI 0000090d [SR] Verify complete\par
2016-05-17 16:16:48, Info CSI 0000090e [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:16:48, Info CSI 0000090f [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:16:59, Info CSI 00000910 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:120\{60\}]"\\??\\C:\\windows\\Microsoft.NET\\Framework\\v2.0.50727\\RedistList" is not owned but specifies SDDL in component NetFx-ASSEMBLYLIST_XML, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = \{l:8 b:b03f5f7f11d50a3a\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:17:03, Info CSI 00000911 [SR] Verify complete\par
2016-05-17 16:17:03, Info CSI 00000912 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:17:03, Info CSI 00000913 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:17:14, Info CSI 00000914 [SR] Verify complete\par
2016-05-17 16:17:14, Info CSI 00000915 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:17:14, Info CSI 00000916 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:17:25, Info CSI 00000917 [SR] Verify complete\par
2016-05-17 16:17:26, Info CSI 00000918 [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:17:26, Info CSI 00000919 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:17:35, Info CSI 0000091a [SR] Verify complete\par
2016-05-17 16:17:35, Info CSI 0000091b [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:17:35, Info CSI 0000091c [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:17:43, Info CSI 0000091d [SR] Verify complete\par
2016-05-17 16:17:44, Info CSI 0000091e [SR] Verifying 100 (0x0000000000000064) components\par
2016-05-17 16:17:44, Info CSI 0000091f [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:17:56, Info CSI 00000920 [SR] Verify complete\par
2016-05-17 16:17:56, Info CSI 00000921 [SR] Verifying 57 (0x0000000000000039) components\par
2016-05-17 16:17:56, Info CSI 00000922 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:17:58, Info CSI 00000923 [DIRSD OWNER WARNING] Directory [ml:520\{260\},l:56\{28\}]"\\??\\C:\\windows\\system\\Speech" is not owned but specifies SDDL in component Windows-Media-SpeechSynthesis-WinRT, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:17:58, Info CSI 00000924 Ignoring duplicate ownership for directory [l:56\{28\}]"\\??\\C:\\windows\\system\\Speech" in component Windows-Media-SpeechSynthesis-WinRT, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type neutral, TypeName neutral, PublicKey neutral\par
\par
2016-05-17 16:18:01, Info CSI 00000925 [SR] Verify complete\par
2016-05-17 16:18:01, Info CSI 00000926 [SR] Repairing 1 components\par
2016-05-17 16:18:01, Info CSI 00000927 [SR] Beginning Verify and Repair transaction\par
2016-05-17 16:18:02, Info CSI 00000928 Hashes for file member \\SystemRoot\\WinSxS\\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\\Amd64\\CNBJ2530.DPB do not match actual file [l:36\{18\}]"Amd64\\CNBJ2530.DPB" :\par
Found: \{l:32 b:z6xRRmOGK5ludcWgPpHG9oEGZPg+oD70KcMRqmqRy7Q=\} Expected: \{l:32 b:n520k714Uu3utHa5JGQ6HQYbZphKhlMWq5pEmfnCDuw=\}\par
2016-05-17 16:18:02, Info CSI 00000929 [SR] Cannot repair member file [l:36\{18\}]"Amd64\\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:24\{12\}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch\par
2016-05-17 16:18:02, Info CSI 0000092a Hashes for file member \\SystemRoot\\WinSxS\\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\\Amd64\\CNBJ2530.DPB do not match actual file [l:36\{18\}]"Amd64\\CNBJ2530.DPB" :\par
2016-05-17 16:18:02, Info CSI 0000092b [SR] Cannot repair member file [l:36\{18\}]"Amd64\\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = \{l:8 b:31bf3856ad364e35\}, Type = [l:24\{12\}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch\par
2016-05-17 16:18:02, Info CSI 0000092c [SR] This component was referenced by [l:166\{83\}]"Package_2709_for_KB3000850~31bf3856ad364e35~amd64~~6.3.1.8.3000850-6825_neutral_GDR"\par
2016-05-17 16:18:03, Info CSI 0000092d [SR] Repair complete\par
2016-05-17 16:18:03, Info CSI 0000092e [SR] Committing transaction\par
2016-05-17 16:18:03, Info CSI 0000092f Creating NT transaction (seq 2), objectname [6]"(null)"\par
2016-05-17 16:18:03, Info CSI 00000930 Created NT transaction (seq 2) result 0x00000000, handle @0x828\par
2016-05-17 16:18:03, Info CSI 00000931@2016/5/17:23:18:03.102 Beginning NT transaction commit...\par
2016-05-17 16:18:03, Info CSI 00000932@2016/5/17:23:18:03.196 CSI perf trace:\par
CSIPERF:TXCOMMIT;134806\par
2016-05-17 16:18:03, Info CSI 00000933 [SR] Verify and Repair Transaction completed. All files and registry keys listed in this transaction have been successfully repaired\par
2016-05-17 16:20:08, Info CBS Trusted Installer is shutting down because: SHUTDOWN_REASON_AUTOSTOP\par
2016-05-17 16:20:08, Info CBS TiWorker signaled for shutdown, going to exit.\par
2016-05-17 16:20:08, Info CBS Ending the TiWorker main loop.\par
2016-05-17 16:20:08, Info CBS Starting TiWorker finalization.\par
2016-05-17 16:20:08, Info CBS Ending the TrustedInstaller main loop.\par
2016-05-17 16:20:08, Info CBS Starting TrustedInstaller finalization.\par
2016-05-17 16:20:08, Info CBS Ending TrustedInstaller finalization.\par
2016-05-17 16:20:08, Info CBS Ending TiWorker finalization.\par
    64-Bit Windows 8.1 Home
Harrier
Central Coast of California
This is not a complaint
Just me thinking did I screw up.......
My last post was 19 hours ago and heard nothing back and I was wondering at my old age and mental ability did I screw up and make a mess of what I did that no one wants to deal with my crap.
Would appreciate a quick reply or some form of message to... well, enlighten me.
Appreciated.... Harrier.
lifetec
What is your current situation.
Did SFC finished with all errors repaired?
Did you try to run restore again?
What is the reason to do a system restore.
Could it be that the problem is solved now that you run the SFC/DISM.
Ps,
We also have a RL, need to sleep, go to work, have a family etc.
    windows 8.1
    self build
    Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
    Asrock P55 Pro
    DDR3 Team--Elite-1333 8 gb
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    OCZ Stealth 600 watt
    Antec 300
    Speedlink Ledos and Nexus
Harrier
OH YES.... I Very much appreciate that you also have a life other than here.
I am very thankful for this site and it's staff... Thank You, Thank You, Thank You
My situation to restore is because there are some hidden cookies that I could not clear and it was making my FireFox behaving weird.
I tried everything and those cookies would not go away, so I thought that A System Restore would clear them out. But my System Restore FAILED because of some corrupt files and that is why I came here initially to get help for me to use System Restore.
You asked me to run the via a tutorial and it took 3 SFC runs to clear those files and I wanted you to gave me the OK after seeing the results of those logs. I think the last one said it was successful but I wanted your go ahead that I should try System Restore again.
Please excuse me.... I am OLD and very SICK.
I APPRECIATE everything that you do..... THANK YOU !!!!
lifetec
Did you try Firefox again now SFC did has found no errors anymore.
Also did you see what i said in the other post about that that particulier website needs possible Flash.
    windows 8.1
    self build
    Asrock P55 Pro
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    Antec 300
Harrier
I tried a system restore again.... it failed
Firefox still won't go to the site I want it to.
But now I use Internet Explorer to visit that site.
NOW... Firefox just upgraded itself here and I checked the site again.... IT WORKS AGAIN !!!
ISSUE RESOLVED. Thank you, Thank you, Thank you for all your time and effort with this
lifetec
great to hear.
    windows 8.1
    self build
    Asrock P55 Pro
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    Antec 300
