Solved system repair disk-installation disk-recovery disk
vasilis
83
hello i have win 8.1 and i'm confused about the differents about these disk i mentioned.
1)can you tell me what are the differents?
if are three different disk:
2)how can create each of them?
3)where is usefull each of them?
4) can i create these disks to usb?
also i have not any installation disk of win 8.1 (my preinstalled os was win 7).i have created a windows image backup.the backup is anything from that?
5) for automatic repair which disk i will create?
sorry for my bad english
    WINDOWS 8 pro
    sony vaio f11
genet
879
    Windows 10
    Lenovo G580
    Intel Core i5-3230M
    8 GB
    Intel HD Graphics 4000
    Microsoft Edge
    Windows Defender, standard user account
    UEFI firmware (BIOS) embedded Windows 8 product key.
vasilis
83
installation media vs recovery disk
hello i'm confused about how can fix corrupted system files and make an automatic repair in win 8.1 withinstallation media or recovery disk?or is the same?also the system repair disk is something different to other two?
    WINDOWS 8 pro
    sony vaio f11
KYHI
2,768
since windows 95 - the recovery disk has been the setup media..
Unless you made custom media
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
Ztruker
A Recovery Disc is usually supplied by the manufacturer and provides a way for you to put your computer back to the state it was in when you first bought it. Same is true for a recovery partition.
Installation media comes from Microsoft and does not have any of the add-ons manufacturers often include, most of which are useless. Installation media allows you to repair a computer or install a new instance of the operating system.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
