Solved System Refresh & Image Recovery problem on Asus Vivotab
JohnF1938
I have made a System Image & a Custom Recovery Image on my Asus Vivotab but I cannot get the system to recognize them on a USB Hard Drive.
I got into this by testing the Refresh Custom Recovery Image. The system did not find the image as the system allocated a different drive letter so I have basic Refresh. I have found my way to the Administrator Command but cannot find RECIMG on either the x: or C: drives. Do I need a Path Command from System32?
I also have a System image on a USB Hard Drive but cannot get the system to find it. I have tried putting the files folders in the root directory but the system still does not recognise them.
No I just copied the files to the USB Drive. The system boots ok its getting the system to find the files.
I think I can fix this if I can find RecImg.
No I just copied the files to the USB Drive. I also have a System image on a USB Hard Drive but cannot get the system to find it.
That won't work. Follow the procedure (previously provided) for your USB drive to be recognized as bootable.
Not sure I understand how that fits into your original post.
http://www.eightforums.com/tutorials/9310-refresh-windows-8-set-custom-recovery-image-active.html
Hope all this information helps!
I have managed to sort it out with a reread of the tutorials.
I copied the CustomRefresh.wim file to the C: Drive.
Found the Elevated command Prompt through Start\Change PC Settings/General/Advanced Startup/Toubleshoot/Advanced Options/Command Prompt
Changed from the X: Drive to the C:\Windows\System32
RecImg /setcurrent "C:\RefreshImage"
Then did a Refresh and got the System back ok.
Thanks everyone for the help.
