System Interrupts abnormal high CPU usage
Anakunda
Hi, usually my laptop had in fully idle state about 1-2% CPU usage. Currently I get approximately 8-10% CPU usage in idle state. From task manager, the most demanding process is System Interrputs consuming between 5-6% CPU.
I suppose this is abnormal high. Can I somehow lower this usage?
Because with 10% CPU the fan is already noisy even if I nothing is performed, annoying.
    Windows 8.1 Enterprise 64bit
Hybrid Vigor
If you are familiar with process explorer tools, you can pinpoint what process is causing the high load. I solved it by installing the newest graphics driver. But it may be any other driver in your system.
    Windows 8.1 32-Bit
    Home made
    Intel Core i5 4670
    AsRock z87m Pro4
    4 GB 1600 12800U
    Intel Graphics 4600
    HD Audio
    SSD Samsung 840 Pro 128 GB
    2 TB WD Green
    Cooler Master Silent Pro MII 420 W
    Cooler Master Silencio 650 Pure
    Semi passive: Thermalright Macho HR-02 Rev.A, Scythe Gentle Typhoon 800 rpm
