Solved "System error 53..." When trying to use named shares
4
I have been using network shares on my home network for a while but as of yesterday I have no longer been able to access them via their name (IP still works fine). This would not be a problem but things like Win8 File Hisotry uses the NAME of the device (e.g., my NAS) and not the IP for making backups.
[ipconfig removed]
Some examples of what happens when trying to connect to my Network Attached Storage (named here as NAS)
C:\windows\system32>nbtstat -a NAS
Ethernet:
Node IpAddress: [192.168.0.203] Scope Id: []
           NetBIOS Remote Machine Name Table
       Name               Type         Status
    NAS            <00>  UNIQUE      Registered
    NAS            <03>  UNIQUE      Registered
    NAS            <20>  UNIQUE      Registered
    ☺☻__MSBROWSE__☻<01>  GROUP       Registered
    WORKGROUP      <1D>  UNIQUE      Registered
    WORKGROUP      <1E>  GROUP       Registered
    WORKGROUP      <00>  GROUP       Registered
    MAC Address = 00-00-00-00-00-00
Bluetooth Network Connection 2:
Node IpAddress: [0.0.0.0] Scope Id: []
    Host not found.
Wi-Fi:
    Host not found.
Local Area Connection* 3:
    Host not found.
Local Area Connection* 2:
    Host not found.
C:\windows\system32>net view \\NAS
System error 53 has occurred.
The network path was not found.
C:\windows\system32>net view 192.168.0.71
Shared resources at 192.168.0.71
NAS
Share name         Type  Used as  Comment
Public             Disk           Public Share
SmartWare          Disk           SmartWare
TimeMachineBackup  Disk           TimeMachineBackup
The command completed successfully.
and another from my Mediacenter:
C:\windows\system32>nbtstat -a MEDIACENTER-PC
Ethernet:
       Name               Type         Status
    MEDIACENTER-PC <20>  UNIQUE      Registered
    MEDIACENTER-PC <00>  UNIQUE      Registered
    MAC Address = 6C-F0-49-98-52-C1
    Host not found.
Wi-Fi:
    Host not found.
    Host not found.
    Host not found.
C:\windows\system32>net view \\MEDIACENTER-PC
C:\windows\system32>net view 192.168.0.65
Shared resources at 192.168.0.65
Backup     Disk
Users       Disk
The "net view" command on its own throws the same error.
This problem does not occur on the Mediacenter or any other computer on the network (all Win7 machines). Here is what the Mediacenter sees for the same share:
C:\Users\MediaCenter>net view \\NAS
Shared resources at \\NAS
NAS
I can RDP into the mediacenter via IP but not its name (MEDIACENTER-PC)
Thoughts/Ideas?
    Windows 8.1 64bit
4
Ok I have done two more things:
1) I have formatted and reinstalled winows 8.1 64bit. Result: no change. From just the fresh installation I am still experiencing the same problem
2) I have replaced the network switches on the network. Result: no change. Everything is now gigabit so I guess that is a plus :)
    Windows 8.1 64bit
play2mefish
162
Ok, what was the issue and what did you do to solve it?
I just go around to reading this and was going to suggest adding a line to your hosts file to tell the computer where to go when you query by name. \
Anyway, glad you solved the problem.
    Windows 8 Pro
    ASRock 990FX Killer
    AMD FX 8320
    ASRock 990 FX Killer
    32gb
    Gigabyte GTX 750i
    Realtek (Stock on MB)
    ASUS 27 HD Monitor & a 37" LCD HD TV Screen (For movies)
    1 250 GB SS hard drive for OS
    1 1TB hard drive for data / mirrored to a second 1 TB hd.
    650W
    No name tower
    Enermax Liqtech 240
    Logitech
    Logitech
    Dnload 10.48 Upload .48
    IE 11 and Chrome when IE doesn't work
    F-PROT
