Switchable graphics with Intel HD 3000 and Radeon HD 7610M
hasona
4
Alright so I've got a serious problem here, my manufacturer which is ASUS in my case will NOT be supporting this graphcis card or the computer itself so I'm left out in the dark.
I have tried with everything and I came to the conclusion that modded drivers works the best which still is pretty bad(switchable Graphics profiles are not saved - Adding Photoshop for example today results that in a week it will be wiped out and the performance will be zero)
The generic AMD drivers does not work, the HP drivers works 50-50, I can Control Everything with switchable Graphics
except for the manual program adding and the modded leshcat drivers are not of my liking.
Considering the fact that AMD supports ENDURO on the whole Radeon HD 7000M series I would expect it to work on the generic drivers.
So if anyone got anything that could help my situation I would gladly hear you out.
I'm thinking that using the modded drivers will be my last desperate move.
P.S. I'm also not using the newest Intel Drivers as they are reported to cause problems
    Windows 8 64-bit
    Asus a53sk
    Core i7 2670QM
    Radeon 7610M
hasona
4
Sorry for bumping but is there anyone that can help with this?
    Windows 8 64-bit
    Asus a53sk
    Core i7 2670QM
    Radeon 7610M
Hopachi
Polyhedric Stellation
Orbiting the Moon
2,975
Hello. I'll try to help here.
Do you know where and how to look for drivers?
Sorry it it sounds silly, I'll give you 2 links to try and search drivers there.
The first sites you'll have to check are:
catalog.update.microsoft.com
and
downloadcenter.intel.com
Regarding the first link, you'll need IE browser and you have to be specific to the exact device name or hardware ID's that are found in Device Manager.
See here for more info about hardware ID:
http://www.eightforums.com/hardware-drivers/6378-idt-hd-audio-not-working.html
For the Intel site is also tricky because it doesn't find always what you search.
If the model is older and no Win8 drivers exist, then you'll have to stick to the modded drivers or at least Win7 drivers.
Good luck
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
hasona
4
and
Good luck
At the moment that I got the modded Leshcat drivers to work you replied :p
Thing is I checked the first link at it says that the latest driver released is from the 18th September well Before any Windows 8 support was given to this driver.
But after trying for hours I finally actually Think I've the leshcat drivers fully working. At least I suppose so since rendering is a lot faster on Revit.
So anyways thanks for the link and I will make sure to use the latest one from there when it releases.
As for the Intel site I already have the latest one from them :)
    Windows 8 64-bit
    Asus a53sk
    Core i7 2670QM
    Radeon 7610M
Hopachi
Orbiting the Moon
2,975
Alright. Good luck further. :)
A problem I got back when using Win8 RP:
On the only radeon-powered computer here, I installed the Application Profile installer and the usability was improved.
link:
http://sites.amd.com/us/game/downloads/Pages/crossfirex-app-profiles.aspx
I don't even have Crossfire or whatever Enduro is (old HD 3600) but it worked!
The problem here was: no drivers available, I was using Win8 preinstalled Engineering-Edition-Driver and some full-screen programs (mostly older games) activated the hot corners all the time. After installing the profiles, all worked just like back in Win7.
If you don't have this yet, try to install a recent one. Some (included on list) programs work better afterwards.
It should work with any (compatible) driver you got there working. ;)
Maybe they'll consider releasing newer drivers soon.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
hasona
4
link:
Quite a coincidence that I actually had those application profiles installed on my PC :p
And they actually fix some problems as you say.
I still am pretty mad that the official AMD drivers doesn't support my
Gfx card, worst of all ASUS have completely abonded my computer model support in WIN8.
This may hurt my long consumer relation to ASUS, if my PC were 2 year's old then I wouldn't complain but it got released in March this year - that's 9month and it is already dead from a support point of view which really is kind of ridiculous!
    Windows 8 64-bit
    Asus a53sk
    Core i7 2670QM
    Radeon 7610M
rogg
1
HI !
Can you post a link to the HP driver ?
i havent found a thing who work!
got a ASUS k53s (k53sk)
    win 8
mhmatas
2
#8
and
Good luck
Hi, which Leshcat drivers are you using? I am facing the same problem!!!
Thanks!
    windows 8.1
mhmatas
2
#9
    windows 8.1
