Solved Stuck scanning/ repairing C drive (chkdsk)
9bjames
Hey, as the thread title suggests, I'm having troubles with a disk check.
Firstly, I'd like to mention that I've had this PC for a while... I've even taken the whole thing apart and swapped out all of the components (slowly upgraded over time). It's actually at the stage where I've been left with all the old parts as spares, and put everything back together, almost exactly as it was when I bought it. All in all, the initial build is probably 2 or 3 years old now (for the most part, the specs can be found here).
After formatting the hard drive, putting things together back with the old build, and booting up Windows 8 onto it as a gift for my dad, most things were working fine, but one exe file which I copied across wasn't running (at least one which I noticed). I checked up the error code, found people with similar problems, and heard it could just be that the file was corrupted.
So, to get to the main point... I figured it wouldn't hurt to run a disk check, in case there were any other errors or problems. I knew it would take a while, so I opened command prompt, and typed in "chkdsk C: /r", before hitting enter, letting it schedule the disk check for next startup, rebooting the PC, and then leaving it to do its thing. It's been running probably for about 4 or so hours now, and for most of that time it's been at 27% on "Scanning and repairing drive (C:)". Normally I'd just give in and force shut down at this point, but I'm wondering... what's the best course of action if it doesn't get anywhere with this?
I'd really prefer not to force shut down, in case it causes any errors... I mean to say the least it's taken some effort and persistence to get the old build up and running again. =/
Any advice would be appreciated, including why it might be sticking at this point in the first place (my guess is because of finding an error it can't manage to fix and getting stuck in an infinite loop or something).
Thanks.
Edit - Ahh of course... sod's law comes to slap me in the face once again... I finish writing this post and submit it, after waiting a couple more hours in case the scan moved along a bit (something like 7 hours into the scan before I submitted this), and it suddenly decides it's finished the exact moment I press submit thread...
Moral of the story - even if it takes forever, just be patient while your PC runs a scan...
Sorry guys, as you were...
    Windows8/ Windows7
    HP Pavillion 6310uk
9bjames
Best option is to just wait it out, and let it do what it has to do. It'll just take a while, especially if you have a large HDD. The disk check didn't really fix the file for me (turned out to be a windows 8 problem), but the main thing was it just needed to be left.
Only consider turning it off if it takes more than 24 hours... Even then, try to avoid that at all costs, and wait it out before giving up.
    Windows8/ Windows7
    HP Pavillion 6310uk
Try typing:
into administrator command prompt & let it finish, then run sfc /scannow.
The dism command takes a long time to run.
It will fix things if they can be fixed.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
dalem8203
Disk Cleanup hangs on Windows 8 update cleanup
I too have had that problem lately. I use Windows 8 Pro and do at least 10 extreme builds per month. I am a Microsoft Tech partner and an Intel Channel Partner. Windows 8 on tonight's load had 56 updates and 3 optional updates. I did the first 28, and the second 28. the the 3 optional updates. I then ran the disk cleanup. Well it hung on the windows update cleanup. There is only two ways to fix this. 1. After each update of 20 or so, and after the restart, run the disk cleanup, and let it run. It will take from 20 minutes to an hour per 20 updates. Or in the alternative, let it run for about 20 minutes, and if it has not finished, restart the computer, and you will see preparing to configure windows, do not turn off your computer! DO NOT TURN IT OFF, BECAUSE IF YOU DO, AND RUN sfc /scannow, you will have log file errors you cannot fix even with chkdsk C:/f/r. chkdsk will hang at 27% and never go on. From there, you might as well reload Windows 8, because you cannot fix the log file errors. You just have to wait it out. I have had it take 2 hours, but if you wait, you will have a good install, and if you don't you will not have an error free load. This is a known problem, and Microsoft is aware of it, and today when they open, I am going find out what they are doing about fixing this issue. I load about 20 machines per month, and I do not have the time it takes to go through this process, so I am going to bug them until the fix this issue. Remember do not reset the computer, let it finish until it reboots or you will not have a good install of Windows 8, and there is no available tool to repair this issue. At least not in Windows itself. My load above just rebooted. The configuration of the 56 updates took one hour and 20 minutes. THE RESTART METHOD IS ACTUALLY THE FASTEST, JUST MAKE SURE YOU LET THE DISK CLEANUP FOR WINDOWS UPDATE RUN FOR ABOUT 10 MINUTES BEFORE GOING TO RESTART. When restarted, run the command prompt as administrator and run sfc /scannow, and make sure there are no errors. HOPE THIS HELPS YOU GUYS. Once this process is complete, disk cleanup will thereafter run normal and fast.
    Windows 8 Pro
    Home Buile Intel Extreme
    i7-3770K
    Intel DZ77RE-75K
    32 GIG
    Nvida Gtx 680 4 gig
    Kaspersky Pure
WirezFree
Same "Clean Disk (Apparent) Hang" ~ But solved
Following the procedure above, which I found when my Win8 Pro appeared hung.
I waited approx 30 mins, then I cancelled the Cleanup, and immediately restarted.
Got the configuring windows message, then some where between 1hr 35mins ~ 1hr 50mins
later the PC re-started.. I did the SFC /scannow. It found errors and corrected them.
I re-started again, NO Configuring Windows message this time.
I then re did the SFC /scannow, this time NO errors.
Hopefully everything will be fine.?
Nothing untoward in the Event log, apart from a pesky intermittent "DNS" error
Great forum, great contributions
    Win 8 Pro
Dragon Drop
I used to get that hang at 27% too. I would hardly say that when a problem arises the first thing to do is buy third-party software to fix it. But, for what it's worth, I found that with the Norton Utilities (which I already had anyway) if you select the "Repair Drives" option it will reboot and do a "CHKDSK /R" with no hang.
    64-bit Windows 8
    HP 23-D030
DragonDon
Anyone know what causes it to be stuck at 27%? And, why 27% what's so special about this number?
I feel like this is a very very specific, Microsoft should know how to fix this, but they have not put out any patches. It really is LAME!
    HP
    3.3GHZ Dual or Triple Core
    8GB
    Intergrated Intel
    IE/Firefox
    Norton 360
Steve06
Mine is stuck at 11%. I triggered check disk through the 3rd party software Puran Defrag that was supposed to do a boot-time defrag and full disk check. I asked it to process two drives, so perhaps this is why the number is different (11% instead of 27%)? Will wait it out as suggested by some.
UPDATE: The total process of scanning the two drives (both SSDs) and defragmenting took about 1.5 hours.
    Windows 8.1 Pro x64
    Custom-built silent Mini-ITX workhorse
    Intel Core i7-3770, 4x 3.40GHz
    ASRock Z77E-ITX
    2x8GB GeIL Black Dragon PC3-12800U
    Intel HD 4000 (integrated)
    Eizo
    Intel SSD 530 240GB, Intel SSD 520 120GB, WD 1TB
    Lenovo Trackpoint Mouse
    Firefox, Chrome
DragonDon
Mine was stuck for MORE than 24 hours!!! I would like to know why!
    HP
    8GB
    Intergrated Intel
    IE/Firefox
    Norton 360
DragonDon
Hey are you saying Scanning and Repairing drive will stuck at 27% FOREVER, or will it eventually finish? I am at OVER 24 hours, and it's driving me nuts! How do you fix this mess? Is there any other way to fix it without a reinstall of Windows?
It's a poor design on Microsoft's part to allow it be like this *SIGH* It's almost like a bug that MS has no idea how to fix, it seems.
    HP
    8GB
    Intergrated Intel
    IE/Firefox
    Norton 360
DragonDon
UPDATE:
Tried to scan again, this time finally the scanning took
over 26-28 hours (In between these times), but it finally did finish. I
am not sure if anything was fixed or not.... yet. About to check this
out.
    HP
    8GB
    Intergrated Intel
    IE/Firefox
    Norton 360
DragonDon
Checking file system on C:
The type of the file system is NTFS.
Volume label is OS.
A disk check has been scheduled.
Windows will now check the disk.
CHKDSK is verifying files (stage 1 of 5)...
621568 file records processed. File verification completed.
8462 large file records processed. 0 bad file records processed.
CHKDSK is verifying indexes (stage 2 of 5)...
737904 index entries processed. Index verification completed.
0 unindexed files scanned. 0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 5)...
Cleaning up 565 unused index entries from index $SII of file 0x9.
Cleaning up 565 unused index entries from index $SDH of file 0x9.
Cleaning up 565 unused security descriptors.
Security descriptor verification completed.
58169 data files processed. CHKDSK is verifying Usn Journal...
35395120 USN bytes processed. Usn Journal verification completed.
CHKDSK is verifying file data (stage 4 of 5)...
Windows replaced bad clusters in file 495645
of name \WINDOWS\WinSxS\Backup\X8E040~1.DLL.
621552 files processed. File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
295659545 free clusters processed. Free space verification is complete.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
No further action is required.
1401479167 KB total disk space.
217869156 KB in 389888 files.
201892 KB in 58170 indexes.
0 KB in bad sectors.
769935 KB in use by the system.
65536 KB occupied by the log file.
1182638184 KB available on disk.
4096 bytes in each allocation unit.
350369791 total allocation units on disk.
295659546 allocation units available on disk.
Internal Info:
00 7c 09 00 45 d6 06 00 e2 16 0c 00 00 00 00 00 .|..E...........
78 26 00 00 40 00 00 00 00 00 00 00 00 00 00 00 x&[email protected]
00 00 1d 53 ea 00 00 00 04 00 00 00 00 00 00 00 ...S............
Windows has finished checking your disk.
Please wait while your computer restarts.
    HP
    8GB
    Intergrated Intel
    IE/Firefox
    Norton 360
OldMX
Check disk s.ma.r.t. status with Crystal DiskInfo
    Microsoft Windows 8.1 Pro 64-bit
    Intel Core i5-3570 @ 3.4GHZ
    Lenovo Mahobay
    16.0GB Dual-Channel DDR3
    AMD Radeon HD 7850 2GB
    LG L192WS
    [email protected]
    Samsung 840 Pro
    Seagate ST31000524AS
    Corsair HX620
    Thermaltake V4
    CoolerMaster Hyper212+
    Dell SK-8115
    Razer Copperhead
    100Mbit up/dn
    Chrome
    MSE (Built-In Windows 8)
masterj6
same crap happened to me
    Cyberpower
    Asus M5A97
    1TB
    2MBPS :(
    Avg 2014
jstearking23
wat
By canceled the setup do you mean you shut your device down? or what and has anything wrong happened recently or in general regarding this incident?
WirezFree
IIRC,
On the little Window that pop's up where it say's "calculating...",
I just kept pressing Cancel till it said "are you sure..."
I did not do a brute force power off...
Dave
    Win 8 Pro
Bigdog333us
Good day. I believe this relates to this thread. Please be kind as I am new and may have done something stupid.
During the AVG disk check, and after it got to 10% and stayed there, I assumed my computer stalled and I forced shutdown and now, although the HP logo screen comes up, there's one short beep and then nothing.
Have I erased my hard drive? Is there anything I can do to make it start to hopefully repair it? (I have no recovery disk) Should I buy a copy of Being a Dummy For Dummies? :eek:
Any help is appreciated.
    HP
Solun
I have the same problem. Ran it through AVG and now it's at 10% for over 2 hours. And it reached 10% quickly. I have almost new Acer laptop with 1 TB hard drive, single unit.
