stuck on update 12/14 for 3+ hours
duro195
Hello,
My hp pavilion dv7 laptop has been updated to W8 about 2 weeks ago and a few updates were succesfuly installed since then. Today though, it downloaded 14 updates and I restarted it so it could install them. The problem is I am now stuck at update 12/14 for the last 3-4 hours. At first I thought it was only a long update, but now I seriously doubt it. I have never ever had an update running that long.
It says I must now shut down the computer during the installation but I can't do anything else either...any tips? I have closed the screen after 3 hours (which puts it in hibernation) but after opening it it went back to the same place...
Thanks a lot!
    Windows 8 pro with media center
brummyfan
Birmingham
Hi duro195, welcome to the forums, switch the power off, try to install one by one( leaving a couple of days in between), one of them or all of them broke my installation yesterday and had to do a clean install. I wouldn't install any updates at the moment.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
duro195
Thanks for the tip. I let it run overnight though and it installed all by itself without my intervention. Unfortunately I forgot to turn off auto update and now it's installing another batch. Same issue. Been stuck on 3/5 for the last 5 hours...I think i'm just going to wait another night and turn off this feature. Maybe in a month that'll be fixed.
I'll email microsoft the issue when my computer is back in service, asking what to do with that.
Is anybody else experiencing this?
CalBear
Northern California
    Dual Win 7-8 64-bit
    Dell Studio XPS8100
    Intel Core i5 3.2 GHz
    8 GB
    Nvidia GeForce GTX 260
    2 x Dell 24" LCD
    1920x1200
    900GB and 1.5TB
    Dell USB
    Dell Optical
    10 Mb/s down 1.5 Mb/s up
    I worked my up from a virtual machine, to a slow 32-bit celeron and now two monitors on my XPS8100. Works great!
James2483
I have a HP too and the updates got stuck on 12%. Tried everything, in the end had to do a system restore
Comp is working but not as good as its use to be.
Are the windows developers aware of this as many seem to have the same problem, are they going to release an update that allows updates to work properly e.g in hp laptops...?
azasadny
Moved to ten*****s.com
Wyandotte, MI (South of Detroit)
I had the same issue with an HP laptop yesterday and I power cycled it after each update was installed. Everything is fine now...
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
RobinP
Hi guys, new here and to Windows 8. Just got a new HP on Monday and this morning, when I turned it on, it started an auto update and now is stuck at 12%. Is there a way to interupt this so that I can go in and reconfigure the settings?
rdwray
Another Win 8 bug... Updates not installing without stopping and restarting the install. When is the real version coming out? I will be using Win 7 until then.
    Windows 8 Pro
    Dell Inspiron 1750
    Duo Core 2.5 G HZ
Metalmania31
That's wierd, I haven't had update issues. Any one think it could be the machines themselves since they're retail builds. Or Antivirus/malware scanner causing the sluggishness?
    Win8.1 Pro 64bit
    Custom Build
    Intel Core I5 3570K 3.4Ghz w/ Zalman CNPS9900NT RT
    MSI Z77A-G45 Gaming
    G.Skill F3-12800CL9D-8GbXL ; 4Gx2
    EVGA GTX 770 Superclocked
    Creative Sound Blaster Z
    Dual ViewSonic VX2770Smh-LED Black 27" IPS-Panel
    Intel 730 Series SSD 240GBx2 RAID0 Win8.1Pro 6GB/s Sata III
    Intel 320 Series SSD 600GBx2 RAID0 Games 3GB/s Sata II
    Kingston Hyper X 240GB SSD Itunes Drive 6GB/s Sata III
    Western Digital Scorpio Black 1TB - Docked via Esata
    Cooler Master GX 750W
    Corsair Vengence C70
    120mm, 140mm.
    Corsair Vengence K70
    Logitech G500 Laser
    Generally 50/Mbps+
    Firefox, Chrome, IE
    Samsung Bluray Optical Drive
    WD 1tb storage backup with Thermatake dock
    Sennheiser 558 Headphones
    Swan M50W 2.1 speakers
    Netgear WNDR4500
rdwray
Normally it is Windows Defender; other updates seem to work most of the time. They have tried to combine a firewall and antivirus and have managed to over power their ability. MS needs to get back to programming and stop playing. Message sent from Win 7 that works...
    Windows 8 Pro
    Dell Inspiron 1750
    Duo Core 2.5 G HZ
