Solved Stuck at BIOS after resizing with Partition Wizard, help!
Sakurai
5
My PC specs: Asus P8Z77-V with a SATA2 WD Caviar Black 500GB. The HDD has four partitions, and I've had Windows 7 32 bit installed on C:/ for three years. Windows 8 was just installed four months ago.
Before this, I had my Windows 8 and BIOS ahci-enabled
C:/Windows 7 <> D:/Stuffs <> E:/Windows 8 <> F:/Stuffs
Yesterday, I needed some space on my F:, so I started Partition Wizard (I used this program a lot before with no problems) and cut 9gb from C, after that queue it to extend F: that much space.
Because C: is located first, but F: is located last, PW created 4 queue, which is cut -> move D: -> move E: -> extend F. The two first actions were performed fine, however when I restart as PW promoted, I was stuck at the BIOS, unable to access BIOS, with the red led lit on the P8z77-v, which means there was a problem with a boot device. If I unplug the HDD, the system goes into BIOS just fine, but obviously can't boot anymore.
There is a lot of important data on that disk which I can't afford to lose. My problem sounds almost like the same as this one:
http://www.eightforums.com/installation-setup/8476-resizing-partition-win-8-stuck-pre-bios.html, however when he changes his BIOS to IDE mode, his HDD booted into Windows 7. However, mine doesn't. I've disabled Secure Boot, but that doesn't work either. It just stucks at the BIOS splash screen.
Currently I am considering to burn a PW CD and hotswap the HDD in order to fix the MBR and stuffs. But if somebody can help me resolve this, I'd be greatly appreciated. Thanks in advance!
    Windows 7 32bit & Windows 8.1 64 bit
    Intel Core i5-3350p
    Asus P8Z77-V
    Asus GTS 450 Direct CU II
    Acer G195HQL
    1400x900
    Caviar Black 500GB
    Tt Esports Challenger Pro
popeye
United States
3,090
Yea, I'm thinking the only thing to do is boot with a repair CD and try to fix the MBR. All that partition moving may have mangled things to the point the MBR is glitched.
You may also want to pull the drive, put it in a USB caddy and pull anything important off it before you start messing anymore with it.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
Sakurai
5
Thank you so much for replying. I'm starting to work on it but my only concern was, if the BIOS can't recognize the MBR, will Partition Wizard recognize the disk if I boot it on CD? Since P8Z77-V is supposed to be hotswap-capable, I'm planning to plug the sata power cable in first, boot the CD and then plug the sata cable last.
Does hotplug work that way? Or I should just get a hotswap bay to be safe? Since I will purchase a new 1TB Caviar Black tomorrow and transferring my old data to it, I might as well get everything necessary. It's just the data I need the most, so thanks for your advance.
    Intel Core i5-3350p
    Asus P8Z77-V
    Acer G195HQL
    1400x900
    Caviar Black 500GB
popeye
United States
3,090
I hot swap all the time with my usb caddy and never had a problem. Another Windows computer should see the drive just fine. I do make sure to eject the drive through the tray usb thingy though. If you use a boot CD, open a command prompt and see if the drive is there when you use diskpart>list volume.
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
hawkman
155
OS bit size
If your profile posting is correct as per screenshot.
i think that partition wizard manager has trouble with you having 32/64 major OS's on the same HDD
    8.1 x64
    x55a asus
    bitdefender
    this laptop was/is still posted on asus website as W7
Clintlgm
Active Member
Lacombe, Louisiana
894
I didn't think that was possible?
    Windows 8.1 Pro MC
    Asus G75VW / Z97 Pro
    Intel Core i7-3610QM / I7-4790K
    Z97 Pro
    16 GB Hyundai HTM315156CFR8C-PB PC3-12800
    nVIDIA GeForce GTX 670M (GF114M)
    VIA 6.0.10.1600
    Samsung 850 Pro 256, Samsung 850 Pro 1TB
    30 down 3 up
    Explorer 11
    NIS and Malwarebytes
SIW2
Team Member
5,360
I have several os installed , different bit versions.
That has never caused a problem for any partition manager.
    7/8/ubuntu/Linux Deepin
Sakurai
5
#8
Alright, thanks for the help guys. So just now I brought the HDD with me to a PC center and ask them to test it. They plugged it their test machine, which already has a HDD in it, and what surpised me was it was able to boot with both of them! My HDD has no problem at all, and all the data/partition is still there, as I can see though explorer. Everything was just like before with an unallocated space between D and E.
I asked the engineer to boot it up and let Partition Wizard do the work. He instead put in a recovery CD just to be sure. The test machine still boots with both the recovery CD and my HDD plugged in. I completed my previous work and rebooted. Didn't even need to rebuild the MBR, the test machine booted perfectly. Partition Wizard shown up to finish what it has started, but of course I cancelled it and proceed into Windows. Everything works just as well as before. I even rebooted another time just to be sure.
So the HDD has no problem. That's a relief. But here I counter another problem. When I plugs my HDD back in my machine, it still doesn't recognize it. Still stucks at BIOS unless I unplug the HDD. The test machine is capable of booting with both my HDD and a recovery CD, mine doesn't. Apparently mine trouble was the same as what the guy I linked in the first post, however when he changed from AHCI to IDE, his machine booted. This makes me wonder, whether the culprit is my motherboard? Or the BIOS, and I can reflash it if that matters.
TL; DR: It seems the HDD never had any problem to begin with, and I'm wondering if it is the motherboard which was faulty.
I will post another update tonight as I bring my whole machine to the PC center and ask them to test both. I just need further confirmations before sending it to the warrant center. (Been wanted to send it previously anyway). Thanks in advance, guys.
    Intel Core i5-3350p
    Asus P8Z77-V
    Acer G195HQL
    1400x900
    Caviar Black 500GB
popeye
United States
3,090
#9
Sure hate it when another problem pops up while in the middle of doing something else. Sure can lead to a wild goose chase. Hope you get it sorted out.
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
