Strange event recorded.
derek10
What does this mean.
ESENT 910 Performance
svchost (1280) The database cache size maintenance task has taken 60 seconds without completing. This may result in severe performance degradation. Current cache size is 9 buffers above the configured cache limit (190 percent of target). Cache size maintenance evicted 1 buffers, made 4149 flush attempts, and successfully flushed 0 buffers. It has run 3796 times since maintenance was triggered.
I have currently 1 similar event that happened some days ago, with different numbers
Windows 8, otherwise, works fine here.
Thanks
    Windows 8.1 64 Bit
    Self built
    Intel Celeron G530
    Gigabyte GA-H61M-S2-B3
    6GB DDR3
    ATI Radeon HD 5450
    Onboard
    Samsung SyncMaster S19B150
    1366x768
    Laptop Toshiba 320GB
    450W
    Old one
    Stock
    Logitech
    Generic
    30mbps
    None
    Netbook Samsung N145 Plus, with Windows 8.1 64 bit and Windows XP SP3, 2GB RAM
Hopachi
Polyhedric Stellation
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
Gweezel
Easy Fix: the problem is Windows Update. From Windows Explorer, right-click on the C: Drive and select Properties. Select the Disk Cleanup button. Wait for the scan to complete. In the new window, select the Clean up system files button. Wait again for the scan to complete. In the new window, make sure the Windows Update files checkbox is enabled. Select OK and Windows will solve your problem.
    Windows 8 64-bit Media Center
    Dell 435MT (Modified)
    i7
    Dell
    12 GB
    Nvidia GTX 660 Ti 2 GB
    Dual 26" LG LED
    21.2 TB (8 TB on board, rest on network raid)
    1000 W ThermalTake
    Logitech G19, G13
    Logitech G600 MMO
    150Gb / 20Gb
Zardoc
Mad Scientist
That fix doesn't work.
Issue comes back.
    Windows 8.1 Pro WMCE
    Monster Rig
    Intel® 4th Generation Core™ 4770K Unlocked Quad Core
    ASUS Z87 A ATX LGA1150
    G.SKILL Ripjaws X F3-12800CL9D-8GBXL 16GB 4X4GB DDR3-1600 CL9-9-9-24
    ASUS GeForce GTX 780 OC DirectCU II 941MHZ 3GB 6.0GHZ
    Realtek Azalia ALC-892
    Samsung SyncMaster SA850
    1920X1200
    Samsung 840 Pro 256 GB Solid-State,
    Samsung 840 Evo Series 250GB Solid-State Hard Drive,
    Western Digital Caviar Black 2x 1TB 6GB/S 7200RPM 64MB
    Corsair Gold fully Modular 80 Plus 850
    Coolermaster Half X Full Tower
    Thermaltake CPU Cooler CLP0556
    Logitech K800
    Roccat Savu Wired
    30 MB
    Firefox 31
    NOD 7
    My fridge has a water tap
    My cat is schizophrenic
    I have a craving for new drivers
BigFatBoy
event 910 ESENT
having the same difficulty myself, I believe the following is worthwhile. it is not THE answer but it may be worth pursuing for a while.
from eventid.net
" The PID...is the number listed in the event description right after the process that reported the problem.
For the example... the process taskhostex ... has a PID = 2524.
To see the PID, open Task Manager and using the View\ Select Columns menu\ check the PID (Process Identifier) option."
there are many cache piles in various places each associated with various processes in W8 (where I am working).
knowing the PID may be helpful.
Also, there is a "Cache" Task in Task Scheduler [CP\AdminTools\Task Scheduler\MS\Windows\Wininet\] that is doing something, what I don't know. However, the text associated with the Event Notice indicates a tremendous amount of work needs to be done, is not being done, and whatever cache is actually effected, is bloated and not be maintained well !!
    W8x64Pro
    Home Grown
    3rd generation intel i5-3570k
    asus p8Z77-V LK with latest Bios: xx11
    16GB samsung 1600 DDR3 (4x4)
    intel 4000 onboard
    Realtek ALC898 - 8 channel HD
    NEC Multisync
    1280 x 1024
    Intel 520 - 180GB
    Hitachi 1TB exterior SATA II backup drive
    Cooler Master Extreme Power Plus 700w
    SuperMicro - 1991 ATX - ivory in color
    intel on cpu. one 92mm chassie intake fan - power supply fan
    ms natural 4000 - usb [love it]
    marathon mouse 705 - logitech
    ATT Max -12Gb/s
    IE 10
    Icon photo of 'Bill the Cat" on the front case cover.
    no color led's or blinking lights
Saltgrass
Some questions, if you don't mind..
Is this a virtual install?
What version of ESET (and be specific please) are you running and what components are active? Have you tried disabling any of them?
Does ESET have some type of self checking utility that might have a log? If it does, since I do not know what might be in it, I cannot ask you to attach it. But you could analyze and pick out possibly relevant parts.
    Windows 8.1 x64
    Home Grown
    i7 3770K
    ASUS P8Z77 -v Pro, Z87-Expert
    16 G
    EVGA GTX 680 Classified (2)
    Kingston SSD 240 GB
BigFatBoy
a question in response to your post above
what is ESENT that it has a version # and components that may be active?
where can I find it?
thank you for any leads on ESENT
    W8x64Pro
    Home Grown
    intel 4000 onboard
    NEC Multisync
    1280 x 1024
    Intel 520 - 180GB
    ATT Max -12Gb/s
    IE 10
Saltgrass
I was thinking about installing ESET to test if I could get the same error, so I needed the specifics so I would have the same configuration. I did not realize this was an old thread.
But I did see something online concerning clearing the ESET update Database. If you have not done that, you might try.
    Windows 8.1 x64
    Home Grown
    i7 3770K
    16 G
    Kingston SSD 240 GB
BigFatBoy
to Saltgrass
You asked about ESENT in an earlier post....
In return, I asked, "What is ESENT? that it has a version # and components that may be active?
thank you for any leads on ESENT"
It appears you are talking about ESET AV and not "ESENT"?
I don't have ESET installed on my PC and was not trying to install ESET at the time I got an error message.
The thread is about an Error in the event viewer referencing "ESENT".
bfb
    W8x64Pro
    Home Grown
    intel 4000 onboard
    NEC Multisync
    1280 x 1024
    Intel 520 - 180GB
    ATT Max -12Gb/s
    IE 10
Saltgrass
Sorry, I started off thinking ESENT was the Anti-virus but had been misspelled. I now see it is some type of Database engine. You can disregard my entire post.
Now that I understand what it actually is, maybe I will do some research.
    Windows 8.1 x64
    Home Grown
    i7 3770K
    16 G
    Kingston SSD 240 GB
