So, I've been running Windows 8 for a year, never had any major problems, till now.
When I'm watching any videos, say a 5 minutes video, I watch 2/3 of them, and the Audio suddenly stops working, at all. There's no sound. Volume bars doesn't show any sound generated, too.
So, first I thought there was a problem with the Audio Driver, so I reinstalled the driver, which didn't solved the problem. Then I completely un-installed the third party audio driver and relayed totally on the Window's default audio driver (Which didn't had the SRS or other effect, but if this problem gets solved, I don't care about that) but that didn't worked, either, same problem.
I tried disabling/re-installing the default driver, too. No luck
But the problems gets solved if I restart the PC. Restarting takes a few little seconds, but it is really annoying to restart the PC in every hour or so.
So, as you can see, I've tried most of the general troubleshooting. I guess you people can help me.
(Note: I really don't want to reinstall Windows)
