Storage Spaces - Users opinions?
gizbug
Chicago
96
Those running Windows 8, do you use Storage Spaces feature? If so, what is your hard drive setup? How do you like it? Reason you are using it? Beneficial? Thanks
    Intel i7
    Gigabyte P8Z68
Coke Robot
Gold Member
5,707
I'm right now not using it at the moment but I've researched the bullocks out of it to give a relatively informed opinion.
Basically, it's real nice.
You can use different hard drive interfaces to combine into one storage pool, which you're able to do a parity or two or three way mirroring. From what I've been told, the parity is a good option to for ULTIMATE redundancy and protect against drive death. But, it appears it's slow as crap to do that, around I think 20-30 MBs/sec. You'd use that for data that doesn't change often, like videos. Two way mirroring is faster, usually around the hard drive's native speeds, and copies your data twice across the pool. This would be used for maybe documents or pictures, depends on how far you want to go.
There is also thin provisioning where you can virtually set a pool to five TBs, but only have 1 TB physically available. As you reach the physical capacity, Action Center will tell you to add more drives to the pool.
The reason I'll be doing it is because I'm a media whore basically. I'm planning on an initial six TB setup with a hard drive cage meant for a RAID as it as alarms to indicate hard drive fault, which Storage Spaces works with as well. If the system detects an impeding death, it will ring off an alarm on the cage. I also demand drive fault resistance as I had a drive die on me and I didn't set up a backup soon enough. Couldn't recover ANYTHING. With that setup, I believe I'll start out with a two way mirror, and then grow it out to a parity for the videos. The benefit here is that you can grow it easily, where as if you did a RAID array, it'd be a tad more technical and tad more complex to do so, but that would be only for an internal drive setup, not external hard drives.
It's beneficial as it's based off Drive Extender from Windows Home Server 2008 I think it was. And it's also superior than it, and works rather decently as I've yet to see problems crop up anywhere on the interwebs. There's a thread I made a while ago about Storage Spaces and a response on there was REAL in depth, I'll see if I can pull it up as that can REALLY help you out.
    ASUS
    AMD FX 8320
    Crosshair V Formula-Z
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
    Microsoft Touch Mouse
pparks1
Westland, MI
3,658
    Windows 7
    Self-Built in July 2009
    23" Acer x233H
    Intel X25-M 80GB Gen 2 SSD
    Corsair 620HX modular
    Antec P182
    stock
    ABS M1 Mechanical
    Logitech G9 Laser Mouse
    15/2 cable modem
Lee
USA, Idaho
1,062
Read up on it, albeit just a bit over my old and dieing brain. . .:cry:
    Win 8, (VM win7, XP, Vista)
    HP Pavilion p1423w
    Intel Core i5 3330 Ivy Bridge
    Foxconn - 2ADA Ivy Brige
    16 GB 1066MHz DDR3
    ATI Radeon HD 5450
    HD Realteck (Onboard)
    Mitsubishi LED TV/Montior HD, Dell 23 HD, Hanspree 25" HD
    Mit. 1980-1080, Dell 2048-115, Hanspree 1920-10802
    1 SanDisk 240Gig SSD, 2 Samsung 512Gig SSDs
    Tower
    Original (Fans)
    Microsoft Keyboard 2000
    Microsoft Optical Mouse 5000
    1.3 (350 to 1024 if lucky)
    Firefox 19.1
    MSE-Defender
