Startup problems
Kynix
Am I int the right place?
Helsinki
340
just about 1 week ago when i started up my pc, it booted windows, but after the 'Windows developer preview' text happens nothing (screen wents black) and just in 30 mins the computer tries to restart. this has happened only once, but i cured it with system restore (no, i haven't installed anything lately) and today, even system restore didn't help. Then i restored my computer (all of my programs are gone...) but i would like to know what is causing this, since it didn't give me any error messages.
    Windows 7 x64 Home Premium / Commodore OS Vision / Windows 8 Release preview
    AMD Athlon x2 Dual Core 7750 BE 2,7Ghz (2/4)
    Asus M2N-e
    4Gb
    GIGABYTE (ATI) Radeon HD 6870 (1Gb)
    Do i have one?
    1x HD1080 1x SXGA
    1x Samsung 500 Gb
    1x Samsung 30 Gb
    1x LaCie 1Tb Hard drive.
    Antec 500W
    Antec three hundred
    3 fans + psu and cpu + gpu
    Logitech G19
    CM Storm Xornet
    110mb/ s
    Look, what i've created... just a few visits at the recyclement center was enough...
vrosa
Tech Addict
The only thing I can say is that it's very odd and without any BSOD data or other detailed info the experts here wont be able to help you :(
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
602
If you can boot do these two things.
There are several ways to find what the problem is. The best is to go into event viewer (type eventvwr in search). Event viewer (local) and look for errors listed in the last day, week, etc. Then go to the windows log>application tab. Finally the windows Logs>system tabs.
You want to look for all errors (they have red in the left column ).
When you find them you want to look for critical errors that say app hang, app crash, or anything that relates to the problem.
When you find them please note the event ID, and the source codes and tell us what they are.
We do need the actual DMP file as it contains the only record of the sequence of events leading up to the crash, what drivers were loaded, and what was responsible.
It is almost impossible to spot trends from a single DMP file so if you have more than one please upload them. If you only have one please wait until the computer crashes again then upload both.
You may be able to get the DMP files without crashing by booting into safe mode (F8) with networking.
To enable us to assist you with your computer's BSOD symptoms, upload the contents of your "\Windows\Minidump" folder.
The procedure:
* Copy the contents of \Windows\Minidump to another (temporary) location somewhere on your machine.
* Zip up the copy.
* Attach the ZIP archive to your post using the "paperclip" (file attachments) button.
*If the files are too large please upload them to a file sharing service like "Rapidshare" and put a link to them in your reply.
To ensure minidumps are enabled:
* Go to Start, in the Search Box type: sysdm.cpl, press Enter.
* Under the Advanced tab, click on the Startup and Recovery Settings... button.
* Ensure that Automatically restart is unchecked.
* Under the Write Debugging Information header select Small memory dump (256 kB) in the dropdown box (the 256kb varies).
* Ensure that the Small Dump Directory is listed as %systemroot%\Minidump.
* OK your way out.
* Reboot if changes have been made.
    WCP
    HP
    [email protected] 4.9 Hz
    64 gig
    Nvidia 9600
    integrated
    laptop
    1440x900
    300gig internal and a bunch ext
    not much
    Built-in
    Logitch Anywhere Mx wireless mouse
    50 down 1.5 up
Kynix
Helsinki
340
i believe, that those files dissappeared/ got removed when i refreshed my pc, also, i did try almost all of the options in F8, but i wondered just one thing... Wheres the safe mode? i didn't find it anywhere :eek: but let's see, if the problems still continue...
    Asus M2N-e
    4Gb
    Do i have one?
    1x HD1080 1x SXGA
    1x Samsung 500 Gb
    1x Samsung 30 Gb
    Antec 500W
    Antec three hundred
    Logitech G19
    CM Storm Xornet
    110mb/ s
602
Check the tutorial section for booting in safe mode.
    WCP
    HP
    64 gig
    Nvidia 9600
    integrated
    laptop
    1440x900
    not much
    Built-in
    50 down 1.5 up
whs
Germany/Florida
4,514
For future security I suggest you image the system periodically. Then it will be easier to get back on your feet.
    Vista and Win7
    5 SSDs and 12 HDs
