Solved Specific network settings based on wifi network
spectre51
Is there a way to setup network profiles or something so that when I bring my Surface Pro to work and connect to the wireless network there it will use the static ip address I have but when I disconnect and then connect to my home wifi it will go back to DHCP? On my MacBook Pro I can go into the network settings and change the location profile I have setup for networks but I don't see anything like this for Windows 8.
    Tablet
    Surface Pro
chev65
Closed
You can go into IPv4 Properties of this NIC, then you can use the Alternate configuration tab to set up the alternate IP, or use the Advanced tab to add a static IP/gateway/DNS etc. to TCP/IP.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Shadowjk
Network Enthusiast
In addition to chev65's post, the Alternate configuration will only be used if the machine is unable to find a DHCP server rather than using the auto configuration address (169.254.x.x)
If your work's wireless network has a DHCP server then it will pick that up over the alternate configuration.
Josh :)
    Windows 8.1 Pro 64-bit ; Windows Server 2012 R2 Standard
    Custom Built
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP (CPU 1)
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD Radeon HD 6800 Series (Sapphire/PCPartner)
    Realtek High Definition Audio
    SMB1930NW + AOC 2243W
    1440x900 + 1920x1080
    977GB Seagate ST31000524AS ATA Device (SATA)
    250GB WD iSCSI attached drive
    750W PSU
    Novatech Night
    Dell Standard PS/2 Keyboard
    R.A.T 7 Gaming Mouse
    Optiarc DVD RW AD-5260S ATA Device
spectre51
Perfect I will setup the static ip for work on the alternate tab and leave the general tab set for my homes dhcp. Thanks guys
    Tablet
    Surface Pro
chev65
Closed
That usually does the trick spectre51.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
