Sony SVT11215SG wireless keyboard not working.
lolcocks
56
Hello,
I recently bought a SVT11215SG - SVT11215SG : VAIO® Tap 11 : VAIO&reg Notebook & Computer : Sony Malaysia
Everything was working great, no issues, upgraded to Windows 8.1 smoothly.
But a few months later, suddenly the wireless keyboard stops working.
I have tried almost everything to get it to work again but nothing has worked so far.
Following are a list of things I have tried:
1. Use the pairing tool. (Got an error saying "Fail to get the dongle handle".
2. Reset the BIOS settings to default.
3. Reinstall Bluetooth and Wireless drivers.
4. Manually remove the drivers from Device Manager and reinstall them.
5. Use the Sony Vaio Care to get the latest updates.
6. Download and install the updates manually.
7. Check Windows Update for any optional updates.
I later found out that the keyboard does not work in BIOS either so I am not sure if it's a hardware issue. But the lights on the keyboard blink as normal when I turn it ON.
What should I do?
Will I really have to reinstall Windows?
If yes, is it okay to reinstall Windows on such a tablet PC?
    Windows Seven
lolcocks
56
Please help guys, the keyboard is not working during Windows installation either and I want to install Windows in UEFI mode but I cannot change certain settings keyboard does not work in BIOS.
    Windows Seven
CountMike
Belgrade , Serbia
4,664
Buy, beg or borrow another, wired keyboard that works. Even if it worked now, if it stops working while you are doing such important stuff you may be left with a brick. Never do that with a wireless device because it may require drivers to work properly.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
lolcocks
56
How do I fix the current keyboard then?
    Windows Seven
CountMike
Belgrade , Serbia
4,664
Do what you have to do using ordinary keyboard and than you'll have better chance to fix what ever is ailing that wireless one. BTW, did you check KB's batteries.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
lolcocks
56
The touch screen works fine, I could always do that to fix it but nothing is working.
Also, the keyboard has a non-removable battery which is charged by placing the keyboard on the screen when the tablet is not in use. The keyboard cannot be opened.
    Windows Seven
CountMike
Belgrade , Serbia
4,664
#9
I just re-installed Windows 8.1 Pro x64.
The keyboard is still not working.
Please help me guys.
Did you check if it needs some special drivers ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
CountMike
Belgrade , Serbia
4,664
#12
Looks like (judging by that message) the BT adapter (or it's program or drivers) can not remember settings. Is that separate USB Bt key or using one built in laptop ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
CountMike
Belgrade , Serbia
4,664
#14
Did you consider chance that KB is just plain broken ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
