somethings wrong with my mouse and desktop
2
hi, i had problems with my mouse if i double left click it turns into right click then i have to right spam some time to get it back to normal. also when i had programs up for example like diablo 3 and skype, while im playing diablo 3 and i try to check skype it wont let me click on skype aswell as other programs. i tend to fix this temporarily by doing Ctrl+Alt+Delete. while playing diablo 3 it gets worse to the point that when i play diablo my character moves on its own because my right click is stuck every 10 seconds pretty much.:shock:i want to fix this problem fully so i have no problems.:D
    internet explorer
    ESET smart security
Otatsuke
I know I'm new here, but my first thoughts are to find the driver for your specific mouse and re-install it, or to get a new mouse.
Since I don't know what mouse you use, I wouldn't know the driver. Even if I did, I probably wouldn't know where to find a copy to re-install. Sorry about that.
    Windows 8 64-bit
    ASUS K55A
    i5-3230M
    4.00 GB
    Kaspersky (With dead subscription)
CountMike
Belgrade , Serbia
4,664
In the Control Panel / Mouse/ see if "Click lock" is on. Also, some programs, mostly games "steal focus" so you can't get out of it's screen with the pointer.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
