Someones phone was connected to my network! Why and how?
karma mechanic
    Windows 8 Pro
ladljaldj
I think this came as a hacker rootkit in Win 8 pro downloaded from pirate bay.
M0xx is russian hacker. He is connecting to your computer through anonymous phone.
Or am i totally wrong here?
    Win 8 pro
ziplock9000
hello same here, m0xx samsung device, iv got virgin superhub as well , seems like in my case the device changes its mac everyday, ( so far by now 3 days in a raw) bloody ms spunks
I have a virgin superhub too and get this issue.. The phone's don't have IP addresses
    Windows 8 64-Bit
ziplock9000
This problem has been around since Windows 7 with devices connected to your neighbors WiFi showing up in either the network map with Windows 7 or on the device list with Windows 8.
It does NOT mean that someone has hacked into your network. It's just showing locally connected devices that aren't necessarily connected to your network. It's not a security leak.
How is this even possible when security is enabled blocked devices from your LAN?
    Windows 8 64-Bit
ziplock9000
As long as your connection point is encrypted and therefore protected you should be all right. I see many strange entities on my wireless network which I use for my iPad and Nexus tablets. It just means they are polling for a signal in the area and not necessarily connected. If you are using an encrypted connection with a nice, complicated pass key then you should be fine.
I think you've misunderstood the issue. The devices are not owned by the owner of the LAN.
    Windows 8 64-Bit
tonymarcus
I have also got a ghost device coming and going, it shows up as a Samsung GT-N7105. Could this be down to a person close by searching for a Wi-Fi network to connect to and it's just showing on Windows as connected but all someone has done has searched on their phone for a Wi-Fi network to connect to?
I have the "Turn Access Control On" switched on so no one could connect to my wifi without the MAC address being added to the access control list so I assume I'm safe.
Tony
Tony
    Windows 8.1 Pro 64 Bit
    Home Built System
    Intel Core 2 Quad Q9450 2.66Ghz, Overclocked to 3.3Ghz
    Gigabyte GA-EX38-DS5
    8GB XMS2 4GB DDR2 PC2-8500
    Gigabyte 660GTX 2GB
    Samsung SMS27B970D
    1xSAMSUNG SSD 840 Pro Series Basic 2.5" - 512 GB - Boot drive
    2xSamsung Spinpoint F1 750GB
    Corsair 520HX
    Antec P182
    Zalman 9700NT
    12Mb/s
    I did a fresh format and install of Windows 8 64 Bit Pro. Sorry but I couldn't live without a start button so I have installed the Start8 start menu which is great. I try sometimes not to use it but find metro frustrating to find programs as I have many. I will use Metro for apps only and desktop of serious computing.
Ex_Brit
Older - But No Wiser
If your wireless router and/or modem is using secure encryption (WPA-2 or better) then they can't connect to it, but you will see strange devices showing up in the network map, that doesn't mean they can use it.
By the same token you can look for other wireless networks in your area and I am pretty sure you wont be able to connect to any of them but then they would see your machine as a phantom in their networks.
    Win 7 Ult SP1 + Win 10 Pro - (x64)
    Alienware® ALX X58
    Intel® Core i7-975 Extreme 3.86 GHz 8MB Cache
    ASUS P6T Deluxe V2 Socket 1366 Core i7, Dual Triple Channel DDR3 Mem
    24GB Corsair Vengeance DDR3 SDRAM at 1600MHz - 6 x 4096MB
    1792 MB NVIDIA® GeForce® GTX 295/Hauppauge HVR2250 TV Tuner
    Onboard Soundmax® High definition Sound
    Samsung XL2370 LED
    1920 X 1080P
    2 X 500gb SATA
    1 X 1TB SATA
    1 X 3TB external eSATA
    (Non-RAID)
    Alienware® 1200 Watt Multi-GPU
    Alienware® P2 ALX Chassis with AlienIce 3.0 Video Cooling
    Alienware® High-Perf. Liquid Cooling + Acoustic Dampening
    Microsoft® Wireless Entertainment 8000 + Logitech® G15 Wired
    Microsoft® Wireless Laser 8000 + Logitech® G9 Wired
    1tbs
    Using non-RAID on purpose as I find it too fussy and temperamental.
crawfish
What determines this? I've never seen anything in the Windows network map that isn't on my network. As for my router, I use Tomato firmware and see the SSIDs of other routers when I use its "Wireless Survey" feature, but I've never seen random client devices there or in its "Device List" page. Seeing other people's "machines" in your network sounds very unusual to me and reminds me of the early days of cable modems.
Ex_Brit
Maybe I'm thinking of a Bluetooth network as those do tend to show all kinds of strange machines in the vicinity, in whiuch case forget I posted.
    Alienware® ALX X58
    Samsung XL2370 LED
    1920 X 1080P
    2 X 500gb SATA
    1 X 1TB SATA
    (Non-RAID)
    1tbs
tonymarcus
I'm using WPA/WPA2-PSK (Mixed Mode) on my router, I think you guys are right, maybe every time my Wi-Fi shows up on someone's phone Wi-Fi search it will show in my Network but like you say that doesn't mean they are connected!
    Home Built System
    Gigabyte 660GTX 2GB
    Samsung SMS27B970D
    Corsair 520HX
    Antec P182
    Zalman 9700NT
    12Mb/s
Ex_Brit
Exactly.
    Alienware® ALX X58
    Samsung XL2370 LED
    1920 X 1080P
    2 X 500gb SATA
    1 X 1TB SATA
    (Non-RAID)
    1tbs
crawfish
I've never seen that happen, and it would be a strange, pointless thing to do. What if you had a party with 10,000 guests? What would be the point of showing 10,000 devices that aren't connected to your network as falsely connected to your network?
ualgun
Has anyone had an HTC One S named ville on their network?
YES! I've spent the last two days frantically securing my whole network and things continued to show up anyway.. One of the early devices that showed up was the HTC One S with the name "ville". I can't remember the mac though..
Since I have two routers running in different locations connected via an openvpn tunnel, I almost shat my pants thinking there was leakage somewhere in my setup..
So far I can confirm that all the devices that showed up were android devices of some form or another. I had the aforementioned ville, a "razorg", a "Bravia 4K 2015".. All of which are apparently android devices.
takeaimnfire
Fixed
Hey guys. Just thought I'd let you know. I was having the same issue, and finally found a fix. For Windows 10 anyways. Turn off your SSID broadcast through your router.
It appears that any device picking up your router's broadcast will briefly show as being connected to your network. Even though its never assigned an IP or anything. This was driving me insane, as I'm overly paranoid, but I'm finally at ease.
Not sure how old this thread is, but it was hard finding any actual useful information on this anywhere, and thought it would be helpful to post.
    Windows 10
Barman58
Super Moderator
Super Moderators
Best way is to change your passcode for wireless to a string of around 30 totally random characters, Upper and lower case letters, numbers and symbols, (write it down and put it in a safe place, the chance of someone breaking into your home to steal a passphrase are virtually zero).
Once all your devices are connected go into your router settings, (change the default SSID and the access user & password, (admin & password, is not that safe ;) ), Also, if you can, switch off the broadcast of the SSID and set the system to only allow devices on a MAC address whitelist to connect, MAC addresses are designed to be unique worldwide, they can be spoofed but this would require some serious hacking which is unlikely for a private individual.
If someone invades your network after doing this then you have a serious issue and would need to consider serious defence of the system Or more likely the person breaking into the system is someone you know who has access to the passwords and router
    Windows 10 Pro x64 x2 Windows 10 Enterprise x64, Ubuntu
    Real World Computing
    AMD FX8350 8 Core @4GHz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    ASUS Xoner DG + SPDIF to 5.1 System + HDMI
    Acer G276HL 27", (DVi) + Samsung 39" HDTV (HDMI)
    1920 x 1080 @60Hz + 1920 x 1080 @60Hz
    Internal
    Crucial 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS
    Seagate ST4000DM000
    Aerocool Templarius Imperator 750W 80+ Silver
    AeroCool X-Warrior Devil Red Tower
    Stock CPU, Rear 120mm, Front 2x120mm, Side 2x120mm
    Logitech Wireless K710 & K270
    Logitech Wireless M710 M185 & M570 Trackball
    37Mb/s Down - 9.5Mb/s Up
    Chrome
    BitDefender Total Security 2017
    Also run...
    Desktop - 6Core 8GB - Windows 10 Enterprise x64,
    Laptop - Quad 8GB - Windows 10 Pro x64
    Netbook - Ubuntu
    2 x Nexus 7 Android tablets
    Samsung 10.2" tablet
    Sony Z3 Android Smartphone
    HTC One Android Smartphone
