Philip Goddard
- Location
- Exeter, UK
I've been doing fine with Win8.1 x64, until a few days ago. At that time there were two changes, one of which I assume to be the culprit. (1) a succession of Windows updates, and (2) my installation of HitmanPro Alert (HMPA) in place of Malwarebytes Anti-Exploit.
Then it crept up on me that I wasn't getting the system beep when I clicked on a program window when I had a dialog box open from that program. The program window title bar would flash, but no sound. Then I realized that I was without the very useful Toggle Keys beeps. Subsequently I found that also the Critical Stop sound was missing in this situation. Not all system sounds were missing - for example, the device connected / disconnected sounds.
This is NOT a matter of sounds having been turned off, at least in the standard manner. When I open the Sounds applet I find all my system sounds are still correctly configured, and all that I test there do play. Also, opening the "Making the keyboard easier to use" section in the Accessibility Centre shows Toggle Keys still enabled - and turning that feature off, applying the change, and then turning it back on and applying the change doesn't make any difference.
It is thus clear that something is blocking those particular sounds or disabling them in a non-standard manner.
I tried uninstalling HitmanPro Alert, and sometimes then got the sounds back after a full shutdown of the computer (but not just a reboot), but currently have now had two computer sessions (full power off in between) without HitmanPro Alert installed, and the sounds have not come back. So, my jury is very much out as to whether HitmanPro Alert is the culprit, though I still have a gut feeling that it is in some way involved, through having changed something on my system that has caused the problem.
I've tried Internet searches for other reports of such an issue, but the search listings are full of stuff about how to turn the sounds on or off (i.e., in the standard way), with no reference to the sort of issue that I have here - so it's too much of a search for a needle in a haystack.
Has anyone else experience of this particular issue and finding a means for resolving it?
