SOD problem!
tuanbusku
usa
1
Hi everyone.
Whenever I try to log off, shut down, restart, hibernate, sleep etc on my brand new computer, the procedure is beeing completed and right before finish, I get the Windows 8 bluescreen...
When I first started using Windows 8 everything worked fine. All power-changes listed above worked and everything was great...suddenly after an windows update these problems started showing up.
Anyone else with the problem?
Anyone with knowledge to fix the problem?
- Thanks.
axe0
BSOD Kernel Dump Analyst
2,369
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
mrjimphelps
"Phelps Helps"
71
Note which update(s) was installed immediately before this problem started, and uninstall that update(s). Then in the future, if that update(s) shows up again, hide it so it won't be installed again.
    Linux Mint 18.2 xfce 64-bit (VMWare host) / Windows 8.1 Pro 32-bit (VMWare guest)
    Dell
    Haswell
    4 GB
    Acer 23"
    Two hard drives, 1TB each: One for Linux, one for my data.
    IBM Model M
    Firefox, Opera
    Sophos (Linux), Trend Micro (Windows)
    I use Samba to share my data drive with the other computers at my house and with my guest session in VMWare Workstation Player.
