So many metro games crash, screen res or graphics driver issue?
Evidently there are some really awesome games in the metro store, but I wouldn't really know because they all either fail to load or BSOD. Notable exceptions: Pirates Love Daisies, which is great and doesn't crash my system, and Cut The Rope, ditto. Mah Jong runs and is an ok game.
Some games (Trump, and Carmen Sandiego) loaded before I figured out how to install my manufacturer's graphics driver, with Win8 running the Microsoft Basic Display Adapter. MBDA failed to recognize my screen's native res of 1366/768, and set the res to 1024/768 (stretched). After updating the driver to Intel GMA 500 8.14.100.2030 both games will launch, but then stall out on the loading screen, eventually reverting back to metro/start but still trying to load in the background.
Other games (Hive Mind) launch and load, but then BSOD when you try to play.
Cut the rope runs but gave me a low memory warning then ran perfectly without any lag.
All in all, this is really a lot of app failures considering that these games are supposed to be optimized for tablets.
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    1GB DDR2 SDRAM (533MHz)
    Intel GMA 500
    Realtek High Definition Audio
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
    Internal 3G (Huawei EM770W:
    HSPA/UMTS 850/900/1900/2100MHz,
    HSUPA: 5.76Mbps (UL) / HSDPA: 7.2Mbps (DL))
1,851
Hi,
You've said the magic term: BSOD
We will fix your machine easily for you. Please see the Crash And Debugging subforum. The top thread details what you have to do so we can fix it.
You can attach the zip requested to this thread here.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Ok, here are the log files.
I had just done a disk cleanup, so I reran the app before grabbing the logs to force a BSOD
Thanks!
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    Intel GMA 500
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
1,851
It's your Intel Media Accelerator bugging out. (That's your video adapter driver in plain English, heh.)
0: kd> lmvm igdkmd32
start    end        module name
8ba25000 8bac3680   igdkmd32 T (no symbols)
    Loaded symbol image file: igdkmd32.sys
    Image path: igdkmd32.sys
    Image name: igdkmd32.sys
    Timestamp:        Thu Sep 16 04:53:44 2010 (4C91DB18)
    CheckSum:         000A1A3D
    ImageSize:        0009E680
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
Let Intel's site scan and it will likely give you a new driver to install:
http://downloadcenter.intel.com/default.aspx?lang=eng
If not, try a Windows Update....if that too doesn't, then let me know....we'll make it happen.
Also a great idea to update the Bluetooth network driver:
btnetdrv btnetdrv.sys Wed Jun 17 01:59:35 2009
and Marvell network driver:
sd8686 sd8686.sys Fri Dec 05 04:22:27 2008
and Realtek HD Audio:
RTKVHDA RTKVHDA.sys Mon Jul 06 05:12:43 2009
Realtek <<< go to High Definition Audio Codec
and Synaptics Touchpad driver:
SynTP SynTP.sys Fri Oct 09 19:50:39 2009
and IVT Bluetooth Bus Drivers:
IvtBtBus IvtBtBus.sys Tue Aug 25 23:12:48 2009
btnetBus btnetBus.sys Thu Sep 24 01:38:41 2009
VcommMgr VcommMgr.sys Fri Aug 28 04:01:13 2009
and either update or uninstall the software that owns these drivers:
ATOM_io_control ATOM_io_control.sys Fri Feb 13 07:38:44 2009
ATOM_CTL ATOM_CTL.SYS Tue Nov 25 18:12:45 2008
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Updating the graphics driver fail
Ok, so I ran the driver update utility and it told me that I have graphics driver 945gm. that's not what my computer says, so I ran the utility again and it told me that I have GMA500, which is what I thought I have. I ran it a third time, and it crashed IE10. I restarted the computer but the update utility continues to crash IE10.
The latest available driver for the GMA 500 and 32 bit Windows 7 is version 5.​0.​0.​2030. The version that I have installed is 8.14.20.2030. When I try to install 5.​0.​0.​2030 (by going into device manager, let me pick, have disk), I get an error that says that "the specified folder doesn't contain a compatible software driver for my device. If the folder contains a driver, make sure it is designed towork with windows for 32-bit systems. If I try to run the driver installer by clicking setup.exe, I get an error that says that the operating system is not supported.
Updating through windows update says that windows has determined the driver software for my device is up to date.
I'll work on updating the rest of those drivers.
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    Intel GMA 500
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
1,851
Hey ya, just awoke from a nap. So here's what to do -
Device Manager - Right click video adapter - Properties | Details tab
Change dropdown to say hardware ids. Copy/paste the results here.
It's either one of two things you've got going on there. Either the wrong driver installed, or since it is the latest as you say, then one of those other drivers I've shown is interfering with its proper operation and causing it to crash. I think it is the wrong driver because it is bug checking 0xD1 which is power state, and it's not a memory corruption type of deal.
So we will focus our abilities on the actual video driver and if the proves unfruitful, the focus shifts to the others, even though the others have to be updated regardless.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hardware Ids For you
PCI\VEN_8086&DEV_8108&SUBSYS_81198086&REV_07
PCI\VEN_8086&DEV_8108&CC_030000
I've been working on updating drivers with mixed success...
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    Intel GMA 500
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
1,851
#8
Yeah, definitely GMA 500. I would also update the motherboard bios if there is an available one. The drivers are the highest priority though.
Which are you having trouble with finding at the moment?
At any time, you can post a new crash dump(s) and we can see where you are at with things...and then take it from there.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
1,851
#9
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
#10
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    Intel GMA 500
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
1,851
#11
heh heh no problems or rushes....it's all good.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
#12
Was having trouble dowlading the realtek driver earlier -- either the problem was with ie Metro view or the download mirror I was using. It's downloading now.
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    Intel GMA 500
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
#13
Ok, I've updated the Marvel, Realtek, and Synaptics drivers.
I don't know how to update the motherboard bios
I'll look for Bluetooth drivers
Shouldn't the graphics driver version 5.​0.​0.​2030 run on my computer? I'm still confused about that.
I launched Hive Mind and it's still causing BSOD
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    Intel GMA 500
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
1,851
#14
Yes, it should run well, but there is another driver still interfering with its correct operation. You can review all I've said about the drivers and also post new crash dumps as I've also said, so that we can look at the system's progress.
Each of the driver issues has to be addressed until the system is "clean".
The latest bios should also be installed. You can visit the manufacturer's website for that.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
#15
Here's the latest log file since updating most of the drivers.
I still need to update the Bluetooth (I found the manufacturer, but couldn't find the driver)
I still need to update the motherboard bios, I don't know how to do this but I'll start trying to find out
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    Intel GMA 500
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
tcman50
Palm Coast FLorida
370
#16
My two favorite games so far are wordwrapit or something like that and a graphical puzzle game, both have been working fine for me :)
    Windows 8 Pro ($39.99 upgrade)
    Intel I5 3570K overclocked to 4.2ghz
    Asus P8Z77-V LX
    Cosrair DDR3-1600 (4 x 4gb)
    Nvidia GeForce GT 610 2GB
    None
    AOC 27" LCD
    1920x0180
    Seagate HDD 500gb (windows)
    Seagate HDD 1.5tb (media)
    Seagate HDD 1tb (media)
    CoolMax 700watt
    Cosiar R400 Carbide series
    Cool Master H212
    Dell
    PowerUp 3 button mouse
    12mb down, 1mb up
    qty. (5) 120mm fans, four are monitored by motherboard.
    Logitech T650 Touchpad for touch screen gestures
1,851
#17
List of what still needs updating or removal:
btcusb btcusb.sys Thu Sep 24 01:35:23 2009
BtHidBus BtHidBus.sys Thu Sep 24 01:36:27 2009
VComm VComm.sys Tue Aug 25 23:11:55 2009
sd8686 sd8686.sys Wed Jun 04 07:24:20 2008 <<< I already posted the update. Either I was wrong with it (it does have new sd8686 though) or you installed it in an unwell manner. Try using the Device Manager to install.
hwinterface hwinterface.sys Tue Feb 24 05:44:18 2009 <<< Belongs to some Windows XP software involving parallel port. Should be uninstalled. You can manually rename the file then reboot:
0: kd> lmvm hwinterface
883bc000 883bd400   hwinterface   (deferred)
    Image path: \SystemRoot\System32\Drivers\hwinterface.sys
    Image name: hwinterface.sys
    Timestamp:        Tue Feb 24 05:44:18 2009 (49A3CF82)
    CheckSum:         0000A1FD
    ImageSize:        00001400
Reference: hwinterface.sys Details. Is this file safe? Check the directory
Reference: How Inpout32.dll works ?
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
#18
Hi GMan,
So, I don't know how to find all those things to audate or remove them. I'm assuming the ones staring Bt are Bluetooth drivers? What if I revert to a generic driver?
sd8686 is the wifi adapter, right? I'll try reinstalling using device manager.
If I'm totally wrong, a little more detailed advice would be greatly appreciated. ;)
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    Intel GMA 500
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
#19
Just tried running the marvell driver you gave me from device manager. It launched but gave me an error message saying "The operation returned because the time out period expired".
Then it crashed the wifi, so I restarted and got a blue screen when win8 couldn't shut down properly.
Want another log file?
    Viliv S10 3G
    Atom Z530 (1.6GHz)
    Intel GMA 500
    SanDisk 64GB SSD
    6.41/5.47 MBPS
    WiFi 802.11 b/g
    Bluetooth 2.0+EDR
1,851
#20
The problem is that the maker of your machine seems to have gone out of business, so they aren't offering drivers or whatnot.
For the Bluetooth: Right click in device manager. Properties. Details tab. Change dropdown to say hardware ids instead. Copy/paste results here.
For the sd8686: Right click, update driver software, browse my computer, let me pick, have disk, browse.
Then double click on the actual inf. Click ok then next. It should install.
Yes, you're welcome to post as many of the crash dumps as you want. More the better. Can see progress or anything new.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
