Small Shield In corner of my downloads
Larryleek
i have downloaded some new stuff lately and there is a shield in the bottom right corner of it, i click the app and it sais "This app cant run on your pc" So i tried to go and disable firewall but i cant click the option of "turn firewall on or off" someone please help Thanks :):thumb:
Larryleek
Firstly my teamspeak app isn't working and has a blue and yellow shield in the bottom right corner of the application when it's on my desktop
secondly I wanted to disable firewall because I personally thought that it was causing the problem
thirdly I have scanned with my av and it had picked up nothing
i will try that last fix soon if it works thanks for the help
elbmek
firewalls do not cause problems, if anything its app setting, or maybe you need to give the app permission to pass through the firewall. Anything that has the potential to link with various unknown sources is a possible danger to the pc. I tried teamspeak once for some reason I cant recall I did not like whatever it was doing so quickly binned it.
your AV wont pick anything up until the software is active, if it picks up anything at all. It would have warned you when you were downloading/installing if anything was there. As TS is an internet programme I would think it would need to be live first.
I use AVG Internet Suite 2015, it has not been beaten yet.
    pc specialist made to order
    Intel® Core™i7 Quad Core Processor i7-4790 (3.6GHz) 8MB Cache
    ASUS® H81M-PLUS: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
    16GB KINGSTON DUAL-DDR3 1600MHz (2 x 8GB)
    2GB NVIDIA GEFORCE GTX 750 Ti - DVI, mHDMI, VGA - 3D Vision Ready
    ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
    iiyama 24 inch flat screen
    1TB 3.5" SEAGATE SSHD, SATA 6Gb/s 7200 RPM (64MB + 8GB SSD CACHE)
    2TB Seagate SATA HDD
    500Gb SATA docked
    In Win Turbo
    Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler
    microsoft mutlimedia keyboard
    logitech corded
    152mb
    FF, IE11
    AVG Internet Security 2015
    16x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW
    10/100/1000 GIGABIT LAN PORT
Larryleek
Yeah I was trying to let things through the firewall but there was that same shield on the button so when I clicked nothing happens
elbmek
try uninstalling it using iobit uninstaller (free), which will also remove anything 'accidentally left behind' and then reinstall watching every tick box and suchlike, see what then transpires.
    500Gb SATA docked
    In Win Turbo
    logitech corded
    152mb
    FF, IE11
Larryleek
One thing I don't get is on the firewall there is a shield next to the text so when I click nothing happens it's starting to annoy me
