Solved Shrinking C drive without affecting recovery options
jayzartisto
I have preinstalled windows 8.1 lenovo flex 2 with 8 GB SSD and 500 GB HD
i want to shrink drive C and create another free drive for data.
will it affect the windows recovery options of refreshing and reseting?
    windows 8.1
Open the Admin command prompt and run: reagentc /info
Please post the screen shot of the result
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Yes, it will unless your new partition is moved to the end after the 14.34GB recovery partition.
There's a hidden 128MB MSR partition which disk management does not show. So counting from left to right, the factory recovery partition is partition #7 as also indicated in the result of reagentc /info.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
