Solved "Shrink Volume" Grayed Out - External Hard Drive
33
Hi All,
I want to format my external hard drive into two partitions so that I can use one of them as a recovery drive for my Windows PC and the other one for my personal data. I am using Windows 8.1.
It is a 1TB WD Elements hard drive currently formatted into one exFAT partition. It is about half full. I don't want to delete the partition and then create two new ones because I have nowhere to backup the files currently on the drive. So I want to shrink the existing partition and then create a new smaller partition but for some reason I can't do that in Windows Disk Management. When I right-click on the drive (E:) The option "shrink drive..." is grayed (as shown in the screenshot).
Does anybody know why this could be? When I right-click on my Windows (C:) drive this option is not grayed out. (I tried doing the same thing using Partition Wizard but I had the same problem - the "split" option, along with a whole lot of others, is grayed out).
Also, another strange thing which might help you to understand. In Partition Wizard, when I right-click on my external hard drive (E:) and click properties it shows that the hard drive is full (first screenshot) even though Windows File Explorer shows that it still has about 500GB of free space (second screenshot)
Why does Partition Wizard (and obviously Windows Disk Management as well) think that the disk is full?
Any help on this would be greatly appreciated!
Thanks,
William.
    Windows 8.1 Single Language 64-bit
    Dell Inspirion 3521-3829
    Intel Pentium CPU 2117U @ 1.80GHz
    RAM: 4.00GB
    Intel HD
    Realtek HD
    Resolution: 1366x768 Refresh Rate: 60p Hz
    Internal hard-drive: 500GB
    D: 3.15Mbps U: 0.46Mbps
    avast! antivirus
topgundcp
San Jose - California
2,847
You cannot shrink a FAT disk. Shrinking is only supported with NTFS. You have no choice but to backup your data and re-initialize it as NTFS.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
33
Ok. Thank you topgundcp. Sorry that is probably basic info that is available everywhere on Google. I just didn't think of it. Any ideas why Partition Wizard shows it as full though?
    RAM: 4.00GB
    Intel HD
    Realtek HD
    avast! antivirus
