Shortcut to switch to Metro view
n4ken
:confused: I need to make a short cut I can place on my desktop to switch to Metro view.
Is there any way to do this?
I have looked hard but can find no info on how to do this.
I do not want to use the keyboard short cut it must be a short cut OR a batch file.
Thanks in anticipation. ;)
    Home build
    Intel I7
    Asus
    8 gig
    Nvidia
Mystere
What's wrong with moving the mouse to the lower left hand corner and clicking on the Start menu button that pops up?
    Intel i7 3770K
    Gigabyte Z77X-UD4 TH
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    2560x1440 + 2x 2048x1152
    Antec SOLO II
    Logitech MX
n4ken
I want to use a Start Menu utility to give me back some of it's functionality.
However some of these utilities change the way things work.
I need to be able to have an icon that I can place in the task bar or on the
desktop that will take me straight to Metro.
This will be useful to me but others may feel it unnecessary.
We're all different...
    Home build
    Intel I7
    Asus
    8 gig
    Nvidia
FSeal
(Subscribing to thread) That does sound like a useful idea. I frankly do not like how that corner button works at all. Having a Metro button right next to the (resurrected) Start button would be pretty awesome.
    Windows 7/8
n4ken
Hi and thanks for the reply.
I had already tried that utility and it does not work on my system. I'm using the Stardock Start8
menu utility and when you run the ShowStart.exe it does nothing!
This is one of the problems I'm having trying to do what I want.
If there was a way 'trigger' the Start Menu in the charms bar that would do what I want.
So, there must be some way of doing this via a shortcut of some sort.
Thanks again for your time.
    Home build
    Intel I7
    Asus
    8 gig
    Nvidia
davidwjohnson
Mouse click to invoke Metro UI
If you have a mouse with programmable buttons: The Windows Key is 'ctrl-esc'
I have a Logitech mouse with programmable buttons. In the Logitech button settings you can program any button to go to the Metro UI:
1.) Go to your mouse settings;
2.) Choose a button;
3.) Select 'Keystroke Assignment;
4.) in the resulting 'Specify Keystroke' - Keystroke window: 5.) Simultaneously press Ctrl and Esc. 6.) Note: In the Logitech example, you cannot use your keyboard key-by-key to enter ctrl+esc. You must simultaneously press the control and escape key in the above window. [Hold down ctrl and esc] Worked for me.
Explanation: I was frustrated that W8 dumped me into the old W7 desktop when I exited an application -- even if I started the application in Metro UI. Then I had to go back to keyboard to press Windows key. Now I have a mouse button to get me back to Metro UI.
Editorial comment - DWJ: I think W8 should default to the Metro UI upon exit from any application. After many months of objecting to W8, I now like it -- but I do not like the extra key press on the Windows Key [on the keyboard] to get me back to Metro UI -- where I started. If Microsoft wants me to use the Metro UI, then Microsoft should dump me into the Metro UI whenever I exit any app.
    Windows 8 RTM
    Dell
    Intel Xeon
    Intel
    12 GB
    Nvidia GeForce 8800GTS
Dwarf
The Contemplator, (1963-2013)
Moderator
I also use the Stardock Start8 utility. If you click on the orb to bring up the menu, the option you want (Windows 8 Menu) should be at the top. Right-click this and choose Pin to Taskbar. A shortcut will appear on the taskbar to the right of any shortcuts already present. You can then rearrange these shortcuts in any order you choose.
To place a shortcut on the desktop, follow the above and after right-clicking choose Open file location. The Stardock\Start8 folder will open, with the target selected. Right-click on this and mouse over Send to. When the context menu appears, click on Desktop (create shortcut). This places a shortcut on the desktop. Unfortunately, this won't work to begin with, so we need to change its properties. Right-click this shortcut and click Properties. We now need to edit the Target: by adding Metro to the end of the data already there (note that there is a space before the word Metro). Once this is done, and changes have been saved, the desktop shortcut should work (at least it does on my computer).
    Windows 8.1 Pro RTM x64
    Dwarf Dwf/11/2012 r09/2013
    Intel Core-i5-3570K 4-core @ 3.4GHz (Ivy Bridge) (OC 4.2GHz)
    ASRock Z77 Extreme4-M
    4 x 4GB DDR3-1600 Corsair Vengeance CMZ8GX3M2A1600C9B (16GB)
    MSI GeForce GTX770 Gaming OC 2GB
    Realtek High Definition on board solution (ALC 898)
    ViewSonic VA1912w Widescreen
    1440x900
    OCZ Agility 3 120GB SATA III x2 (RAID 0)
    Samsung HD501LJ 500GB SATA II x2
    Hitachi HDS721010CLA332 1TB SATA II
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    XFX Pro Series 850W Semi-Modular
    Gigabyte IF233
    1 x 120mm Front Inlet 1 x 120mm Rear Exhaust
    Microsoft Comfort Curve Keyboard 3000 (USB)
    Microsoft Comfort Mouse 3000 for Business (USB)
    NetGear DG834Gv3 ADSL Modem/Router (Ethernet) ~4.0 Mb/sec (O2)
    IE 11
    Avast! 8.0.1497 MalwareBytes 1.75.0.1300
    Optical Drive: HL-DT-ST BD-RE BH10LS30 SATA Bluray
    Lexmark S305 Printer/Scanner/Copier (USB)
    WEI Score: 8.1/8.1/8.5/8.5/8.25
    Asus Eee PC 1011PX Netbook (Windows 7 x86 Starter)
Dave44
just press windows key
    Windows 8.1 update 1 Pro X64 with WMC
    intel i7 2600k
    Asrock H61M-VG3
    16GB
    nvidia geforce GTX 560 Ti
    100MB
n4ken
Hi Dwarf, I had already seen the item on the top of the menu but never thought of pinning it to the task bar... good one.
This short cut uses an internal command to start8 so it is not possible to make your own short cut actually on the desktop.
I'd still be interested to find out how to do this. MS included lots of keyboard short cuts but neglected to include this.
I'm using windows 8 as my main system and have to say I'm finding it reliable and good to use overall.
It's strange but learning to use a new os teaches you how to use the older os better! I've discovered many little
tips and trick for windows 7 since I started using windows 8. There's no going back as far as I'm concerned...
Windows 8 is much better than many others say and it will get better as we find out the tips and tricks we had
built up over the years on windows 7.
As far as Metro goes... I love it for some of the apps available now especially the news. I look forward to more
'TRUE' Metro apps as they come along.
Thanks all.
    Home build
    Intel I7
    Asus
    8 gig
    Nvidia
Dwarf
Moderator
I explained above how to add the shortcut to the desktop. ;)
    1440x900
    Gigabyte IF233
    IE 11
