Shortcut icons keep changing?
I have been using Windows 8 for a while now and I have noticed a strange problem.
It appears that the shortcuts on my desktop keep having the icon changed (the arrow).
Here is what it should look like normally (I think):
Here is it with a different icon:
Here is it with another icon (from sync center?):
And another (notice the two UAC Shields on the second one):
And here with nothing at all:
What do you think could be causing this? I'm pretty sure I re-installed once and still had the problem. It seems absolutely random and rebooting doesn't really change it. Also I am not sure if this is the right thread, couldn't really figure out what fit.
    Windows 8 Pro x64
    Intel i5-3570k @ 4.2GHz
    Gigabyte GA-Z77-D3H
    G.Skill Sniper 1866 2x4GB
    HIS Radeon HD 6770
    1920x1080, 1680x1050
    Intel 330 Series 60GB
    Seagate Barracuda 3TB 7200RPM
    Apevia Iceburg 680W
    NZXT Gamma Classic
    36/34 FTTH
Microangelo perhaps ????
I can do things like that with Microangelo on Display.
Do you have Microangelo ?
See picture--
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Never even heard of that until now. Can't find any trace of it on my system. You think installing it could help?
And here is the latest one:
    Windows 8 Pro x64
    Gigabyte GA-Z77-D3H
    HIS Radeon HD 6770
    Apevia Iceburg 680W
    NZXT Gamma Classic
    36/34 FTTH
cmlusco
22
Almost seems like a notifications feature. Downloading update - arrow down, installing update - installer icon, and updated - checkmark. And then of course the regular shortcut arrow. The uac shields mean that program is set to always be run as administrator, without specificly having to do so.
I googled to see if it was a feature but couldn't find anything about it, nor anyone else asking the same question. So in other words i have no clue lol. I know im just so helpfull. :)
    Windows 8 Pro With media Center
    Self Built
    Intel Core 2 Quad Q8300 @ 2500MHz
    Gigabyte EP43-UD3L
    4096MB (2 x 2048 DDR2-SDRAM)
    nVidia GeForce 8600 GT (512MB)
If you never heard of Microangelo that's not the problem.
It's a program for dealing with icons.
Rather complicated & NOT cheap.
I think a better solution should be available.
Maybe a System Restore from a time when the problem did not exist.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
