Setup program unreadable when using a Geforce 8400 card
jeeves
2
When I run the Windows 8 setup program the screens are nearly unreadable. There is a screenshot of this below. I'm not even sure how to describe the garbled text effect for googleing purposes.
While I was able to finally get Windows installed with a lot of guessing at what was on the screen, the video problem persists. I suspect this is some sort of driver issue, but I am not able to download and install the latest drivers from Nvidia because the screen is so unreadable.
I tried booting up in Windows restricted graphics mode (I think that was F5 in the special boot menu), but the problem persists. Same goes for booting up in Safe Mode.
I know this computer is OK, because I was able to install Window 8 on it just fine when using the integrated graphics. Also I am currently dual booting Windows XP (using the Geforce card), and it it does not have the same problem.
Can anyone shed any light on this?
    Linux
Ztruker
Sounds like the 8400 is defective. Can you try it in another computer or try a different card in this one.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
jeeves
2
I doubt it's the card, because it would be having problems when I boot into other OSes. This is currently being used on a triple boot computer, where it does just fine running Windows XP with the latest Nvidia drivers, and Opensuse Linux with the open source Nouveau drivers. It's only on Windows 8 where there is a problem.
    Linux
theog
Gold Member
5,591
Try using the VGA port & a VGA Monitor.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
Ztruker
Try the Automatic Driver Detection at the Nvidia web site, see what that tells you: Drivers | GeForce
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    [email protected]
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
TONSCHUH
Wynnum Australia
466
Double-Checked the Refresh-Rate in your settings ?
    Windows-10-Pro-Build-11099.rs1-x64
    Custom-Build
    Intel Core i7 3770k @4800MHz
    Asus P8Z77-V
    G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
    2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
    OnBoard Realtek® ALC892 8-Channel High Definition Audio
    Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
    - Samsung 840 EVO SATA3 500GB
    - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
    - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
    Corsair AX1200i
    Thermaltake Level-10 GT LCS
    EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
    Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
    ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    - Logitech Extreme 3D Pro Joystick
    - Plantronics GameCom Commander Headset
    - Logitech X-210 Speakers
    - Roccat Taito Mid-Size 5mm
    - PC-Master-Race MousePad (yellow)
