Solved Settings>change pc settings problem
freezcool
Settings>change pc settings problem and questions
solved
    windows 8.1
    asus rog g750jw
caperjack
Just the Janitor
hello, i'll only answer 2 question ,#4and 5.that all I use for over 2 years now , and have had no issues at all with the 3 program uyou mention ,but iam a safe surfer in my own opinion .
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
KYHI
Macrium will create a full system image and when used it will restore to the point the image, any changes after image creation will be lost..
System Restore will undo recent changes - say you install a program and something happens - it will restore back to before program
Custom Refresh Image is some what like marcium except it only creates an image of the windows partition, not the system..
And I only use windows defender.. I just don't care to use 3rd party software..
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
freezcool
i just tried system restore just now to undo my recent installed program, however still there's folders leftover. So if i use macrium, there would be no left over? Thnx
    windows 8.1
    asus rog g750jw
