Serious problem with graphic card
yszty
Hello everyone, i need help with that "strange" problem. I installed Win 8 64bit with my old graphic card 9500gt inside, everything was perfect. Just after windows installed, i shut him down and changed graphic to 660gtx, i did it this way cause 660gtx is so big and to use it i must remove one SATA connection (dvd). With 9500gt windows works rly good but when i change to 660gtx i can't see single word, screen is blurry and windows 8 don't recognise my 660. Everything is fine on Win XP. I don't know what to do right now. Can it be problem with my motherboard with bios update max to Win 7 64bit, Win8 is not supported anymore by this board. If yes, there is any solution with NOT buying new board? Sorry for my english.
    Win 8
CountMike
Did you cleanly uninstall drivers for the old video card first ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
OldGuyGeek
A clean install of the 660 NVidia drivers should work, but if you can't read anything good enough to do a clean install, put the 9500 back in. Then uninstall the NVidia drivers and allow Windows to run from the generic drivers.
Then put your 660 back in, download and install the correct NVidia drivers for your 660.
Don't worry about your bios not officially supporting Win 8. It should be fine.
    Self Built
    Intel I-7 860
    Asus P7B
    8GB
    Nvidia 580
    Acer (Primary), Asus (secondary), Sony TV (third)
    Kingston 128GB SSD Windows 8 Boot Drive
    WD Black 1 TB (2 ea)
    WD Red 3 TB
    WD Black 500GB
    MS 1000
    MS Flip
    Verizon FIOS 35/35
    IE 11, Google Chrome, Firefox, Opera, Safari
    Windows 8 Defender (MS Security Essentials)
yszty
Problem is that, Windows 8 don't see my gtx660... i can't even install drivers cause it says when i want install driver for gtx "Graphic card not detected" :/ maybe clean install of Win8 with already inserted gtx will help cause he will automaticlly find it..
    Win 8
Nemix
Is you power supply sufficient for the GTX 660 graphics card and have you checked to make sure you've connected the external
6-pin PCIe power connector from your power supply to your GTX 660 graphics card?
    Intel Core i7-2670QM
    Samsung 8GB
    NVIDIA GT 555M
    Intel 525 120GB | HGST Travelstar 1TB
    CM Storm Xornet | Microsoft Sculpt Comfort
    25 Mbps | 600 Kbps
    Seagate Backup Plus 1TB
yszty
Yep, it is connected :/ i have similar display problem to "Bus artifacts", if u google it u will see what i'm talking about.
    Win 8
Nemix
Did you buy the card brand new or used from someone?
Are you certain the power supply is sufficient for the GTX 660, what is the rated watts of your power supply?
Also, does you motherboard's BIOS have a setting to lock the PCI Bus speed at 100Mhz?
    Samsung 8GB
    NVIDIA GT 555M
    25 Mbps | 600 Kbps
