Scanning and repairing volume (\\?\Volume...) on startup
Herbalizt
Hello Guys,
this is my first post on eightforums,
i recently got a new laptop "asus vivobook" that came preloaded with windows 8.
The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery)
i deleted the recovery partition and made a recovery on an 8 GB usb drive,because im dual booting a different linux os alongside windows.
I used rEFInd boot manager to boot the 2 operating systems,everything boot and works fine.
However,since the dual booting started i noticed that the windows 8 loading time has became a bit slower,when i choose to sart windows 8 the asus logo appears and under it this message
"Scanning and repairing volume (\\?\Volume{...large hex identifier..}): 100% Complete"
it stays for 2,3 seconds and then windows 8 start,i ran a chkdsk for the c drive,but that didnt solve the problem.
Is there any way to fix this issue,
Thanks.
    Asus
    i7 3537U @ 2.00GHz
    8 GB
    Nvidia
owenspal
The problem you are seeing could be caused by the Win8 "fastboot" feature. Disable fastboot and see if that fixes the problem. It can occur on dual boot and other multi partition configurations.
    win8.1 pro
    Home built
    3.1ghz PhenomII
    ECS Elitegroup A880GM
    4gb ddr3
    ATI HD4250 (onboard)
    SSD for OS, HDD for data
Saltgrass
If you copy the partition identifier, including all the designation and paste it into a run command, it will open that partition in Explorer. That would tell you which one it was, since it probably does not have a mount point.
If you installed Linux, did you use a UEFI and Windows 8 Secure Boot capable version?
    Windows 8.1 x64
    Home Grown
    i7 3770K
    ASUS P8Z77 -v Pro, Z87-Expert
    16 G
    EVGA GTX 680 Classified (2)
    Kingston SSD 240 GB
Herbalizt
fastboot is disabled already.
    Asus
    i7 3537U @ 2.00GHz
    8 GB
    Nvidia
Herbalizt
the Linux os is mint and it supports EFI.
    Asus
    i7 3537U @ 2.00GHz
    8 GB
    Nvidia
Beerman
Did you ever figure this out? I have the same EXACT problem.
    Win 8.1
    AUS Custom built
    Intell 3770K
    P8Z77 WS
    16 GB corsair
    Nvidia GTX 650 Ti
    Defender
greier
Hi , i have the same problem on my ASUS laptop. I just install windows 8 professional with an original serial .how can i solve this issue??
[h=2]"Scanning and repairing volume (\\?\Volume{...large hex identifier..}): 100% Complete"[/h]do you guys figure out?
    WindowsS 8 professional
Saltgrass
Greier, did you follow the instructions and find out which partition is involved?
Are you running more than one OS and have you also made changes to your original configuration as the OP had done?
    Windows 8.1 x64
    Home Grown
    i7 3770K
    16 G
    Kingston SSD 240 GB
greier
Previously i had windows 8 rtm core. I deleted/create again the partition C and i install windows 8 professional. i had some problems with serial it was an error : <The product key will not work with this edition of windows 8 You must either run windows 8 setup or enter product key> I clik on <Add features to your edition> and after uptades it worked but i have this startup message. How can i have more than one OS? I formatted the C partition (sorry form my english . it's not perfect) so where is the problem? :(
I olso copy and paste the code in run command and still don't get it :( what can i do?
greier
hey guys :) i`m back...with a good news: i fixed the problem!
at the beginning i had 5 partitions, and i deleted them all, but still they were not erased, only the data was deleted.
after having installed Windows, a new partition appeared, besides the others i had ((C:)Windows and (D:) Data); this new partition only had 900 Mb; so i removed all the partitions i did not need and added the unpartitioned space to the D partition using computer management/data management. below you can find the link with more explanations. hope it helps others too. have a good day! greier out :)
https://www.youtube.com/watch?v=sGmfKYRzDtQ
