Samsung Laptop Not Charging
Pajee
11
I think the laptop is fully functional but it can't charge. It ran out of battery now. I think the power supply is working because there was a green light :D.
Is it caused by a problem in its motherboard?
    Windows 7 Professional
KYHI
2,739
could be a loose connection with the MOBO power jack - some power jacks are plug in and some are soldered on
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
Pajee
11
Thanks for the reply.
I was thinking about that. I watched a video on youtube of how he fixed his power jack by soldering a loose wire. On the video he said that on some computers, you may not be able to remove the power jack. We'll probably send it to computer repair for now and then try that. :D
KYHI
2,739
search your PC - power jack
ie dell 1521 power jack
    Dell XPS 8700
    I7
    24 GB
KYHI
2,739
the power jack is where you plug the adapter into the pc - that is your power jack
    Dell XPS 8700
    I7
    24 GB
