I have a Samsung 850 EVO 1 TB drive for the OS, with Magician software installed, for about two month. The software reports drive health status as good, total bytes written is 0.62 TB.
As of late, it has started to crash hard. The system reboots after the crash, runs for awhile and rinse and repeat. Sometimes runs for days without crashing.
The log entries for these events are non-descriptive:
This system dual boots with Windows 7 (Intel SSD), via F12 in the BIOS. In another words, Windows is not used for dual booting. W7 started to have the same issue, hard crash without memory dump. Removing the Samsung SSD seemingly stabilized W7.
Tested the memory, came up clean, nor did it have any issues in W7. Uninstalling/reinstalling Magician software didn't make a difference in the periodic hard crash in W8.1. Shrinking W8.1 "C" partition to 250 GBs seems to resolved the issue, at least for the last couple of hours.
Anyone has an idea how to test SSD drive faults?
The temperature, voltage, etc., of the system seem OK, I don't believe that it could be the source of this issue:
There's no memory dump, enabled, since this is a hard crash.The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
