Same settings as 7, access denied on 8.
AmigaRoots
Joined
Oct 28, 2012
Same settings as 7, access denied on 8 wired network.
I have a small wired home network of 2 PC's. Everything worked fine on 7, on 8 I can see and open shared folders/files but cannot modify/delete them. You can see my settings below, common on both PC's. Tried both on/off for "turn on automatic setup...". On the shared folders in the 2nd PC, full read/write access is given to "Everyone" (using same settings that worked on 7). I've tried disabling security software and the router's firewall. Also tried using Homegroup and UAC on/off.
Nothing works. :huh:
    Windows 8.1 Pro x64
    Custom built
    Intel Q9650 (3GHz)
    4 GB
    AMD 5670
    2 X Dell
    1680x1050
area 66
Banned
Joined
Feb 29, 2012
WOW, you give access to about anyone on the net to your stuff. If you can open and read a share folder and can't delete a files, it's a permissions problem, the firewall on your router as nothing to do so enable it. I don,t know where to start to help you, you change so many setting. First: did you have the exact user name / password on both PC ?
Please try to avoid Image shack, use Photobucket, image shack open a lot of crap when we try too look at your pics
    Windows 8 enterprise x64
    Pc-Quebec / Area 66
    i7-3960X Extreme Edition
    Rampage IV Extreme
    Gskill 4x4 GB
    4 x HD 7970
    onboard
    2560*1600
    C:\Intel series 520 SSD , 250 GB
    D:\ WD 750 black with Intel 40gb SSD cache Intel RST
    E:\ WD 2TB Black
    Corsair AX 1200
    TT Mozart TX
    Water Cooled
    Logitech G-15
    Windows 8 VM is install on his own SSD.
    Country Flag
    Canada
    State/Region Flag
    ca quebec
AmigaRoots
Joined
Oct 28, 2012
I usually use "Authenticated Users" instead of "Everyone", did that for testing. If you mean if they remained the same after upgrading to Windows 8 then no. I think 8 requires an extra setting (Computer description) which might cause these problems.
    Windows 8.1 Pro x64
    Custom built
    Intel Q9650 (3GHz)
    4 GB
    AMD 5670
    2 X Dell
    1680x1050
chev65
Closed
Joined
Jan 28, 2010
Beach house paradise
With Windows live account I had to authenticate my Homegroup machine names through email process.
Do you have a Windows live account? Did you authenticate the machines in your Homegroup yet?
    Windows 8.1 Pro WMC
    Name
    Rob
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Occupation
    Construction Engineer
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
    Country Flag
    USA
    State/Region Flag
    us california
AmigaRoots
Joined
Oct 28, 2012
I've only created a new account (with a current non-Microsoft email) for access to Store etc. and use it on both PC's. How is authentication done? Also, I am not using HomeGroup (I did try it, but had the same problems).
    Windows 8.1 Pro x64
    Custom built
    Intel Q9650 (3GHz)
    4 GB
    AMD 5670
    2 X Dell
    1680x1050
chev65
Closed
Joined
Jan 28, 2010
You might want to try setting up a Windows live account as pretty much everything in Windows 8 seems to revolve around that account.
Other than that it sounds like a permission issue.
http://www.eightforums.com/tutorials/9990-file-sharing-set-share-stop-sharing-windows-8-a.html
    Windows 8.1 Pro WMC
    Name
    Rob
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Occupation
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
    Country Flag
    USA
    State/Region Flag
    us california
